What Is the Electrical Field Magnitude at Each Point Due to the Charges?
The discussion centers on calculating the electric field magnitude at two points in a rectangle due to two point charges placed at opposite corners. Participants explore the application of the formula E = kq/r^2, addressing confusion over the correct distances and signs for the charges. They clarify that the electric field is a vector quantity, requiring both magnitude and direction for accurate calculations. The conversation emphasizes understanding the underlying physics, particularly the inverse-square law, rather than just solving the equations. Ultimately, the participants work through the calculations, correcting errors and reinforcing the importance of conceptual clarity in physics problems.
baird.lindsay
Two point charges are placed at the opposite corners of a rectangle as shown. What is the Electrical Field magnitude at each point due to the charges?
Pythagorean theorem, E=kq/r^2
r= square root of .8^2 +.4^2 =.89
E= 8.99x10^9 X 4X10^-6 divided by (.89^2)
E=8.99x10^9 X 2X 10^-6 divided by (.89^2)
should I not be dividing by .89^2 but rather the radius of an electron?
I am not sure if A and B should be negative or positive or if I am doing this right..?
A and B are points, they are neither negative nor positive.
However, you do need to bear in mind that the electric field is a vector - you only have the equation for the magnitude.
Note, charge 1 is twice the size of charge 2.
For each point, one charge is twice the distance that the other charge is.
It's worth thinking about this - if you double r, then E goes down by... but what if you also double q? ... halve q?
I don't really understand because to find the vector i need to use square root of e in the x direction squared + e in the y direction squared...
I don't get how to find the vector in the x direction ...I have E= kq/r^2 or 8.99X10^9 X 4X10^-6 / (.400^2)
but my professor crossed off .89^2 so I think I did that wrong?
im getting 226499 N/C for Point A and 125639 N/C for Point B...?
What is the field at point A due to the 2μC charge?
Which direction does it point?
What is the field at point A due to the 4μC charge?
What is the total field vector at point A? (use i-j-k notation if you like)
What is the magnitude of the total field at point A?
simon bridge said:
what is the field at point a due to the 2μc charge?
112375 n/c in the y direction
what is the field at point a due to the 4μc charge?
56187.5 in the x direction
what is the total field vector at point a? (use i-j-k notation if you like)
112375i + 56187.5j
what is the magnitude of the total field at point a?
125639 nc
The magnitude at A and B are the same.
@barryj: we'll see...
it's no good to have the answer - you need to have the physics.
Please read the PF rules.
@baird.lindsay:
I think we've identified some confusion here ...
... etc... please show your working.
1. electric field at A due to 2 microCoulomb charge:
##E_1= kq_1/r_1^2##
##k=8.99 \times 10^9 \text{N.m}^{-2} \text{C}^{-2}##
##q_1=2\times 10^{-6}\text{C}##
##r_1=4\text{m}##
##E_1=1123.8\text{N/C}## direction: "upwards" (note: axis not defined in problem)
Want to try that again?
2. the field at point A due to the 4 microCoulomb charge:
##E_2=kq_2/r_2^2##
... what are each of the values?
3. E vector is
4. magnitude of E ...
note:
if ##\vec{E}=E_x\hat{\imath}+ E_y\hat{\jmath}##
then ##|\vec{E}|=\sqrt{E_x^2 + E_y^2}##
@baird.lindsay:
I think we've identified some confusion here ... ... etc... please show your working.
##E_1= kq_1/r_1^2##
##r_1=4\text{m}##
##E_2=kq_2/r_2^2##
##E_2= kq_1/r_1^2##
##q_2=4\times 10^{-6}\text{C}##
##r_1=8\text{m}##
##E_2=561.9\text{N/C}## direction: "leftwards"
3. E vector is
##\vec{E}=561.9\hat{\imath}+ 1123.8 \hat{\jmath}##
note:
if ##\vec{E}=561.9\hat{\imath}+ 1123.8 \hat{\jmath}##
then ##|\vec{E}|=\sqrt{561.9^2 + 1123.8^2}##
therefore 1256.4 N/C
is this correct?
is this correct?
You can edit the quote by inserting extra close and open-quote tags.
Note: the i direction is usually to the right horizontally - the direction of the field at A due to the 4mcC charge is to the left ... i.e. the -i direction. But it makes no difference to the magnitude.
I don't check people's arithmetic - but your method is now correct.
Can you see where your thinking was out before?
Now you can repeat for point B and see if Barryj was right ;)
no they are different...i get it now ..thanks for all the help..this was driving me crazy!
Just take things a step at a time - but notice how you didn't really need anyone to tell you when you had it right?
Did you figure out how you were going wrong the first time?
I stand corrected. Humble pie tastes terrible.
Don't beat yourself up.
As you advance in science you will find you are wrong far more times than you are right - that's the only way you can be sure of anything. The trick is to be wrong in the right way... so you can learn from it ;)
http://www.ted.com/talks/kathryn_schulz_on_being_wrong.html
It is a very common tactic to get you familiar with how the equations work by giving you problems where things get doubled and halved. This is a case in point.
It's worth thinking about this - if you double r, then E goes down by... (how much?) but what if you also double q? ... halve q?
The point of the exercise is to understand the inverse-square law, not just be able to do the math.
