Coulomb's Law (positive & negative charges)
A charge of +4.3 C is indeed a positive charge, as the sign indicates. The charge of one electron is -1.602 x 10^-19 C, while a proton has a charge of +1.602 x 10^-19 C. Therefore, the confusion arises from the misunderstanding of charge signs; +4.3 C does not imply a negative charge. The elementary charge is denoted as e, with protons having a charge of +1e and electrons -1e. Understanding these fundamentals clarifies the nature of positive and negative charges.
ND3G
I need to draw a single point charge with a magnitude of +4.3 C (coulomb's)
I want to make sure that I am doing this right so:
If one electron equals 1.602*10^-19 C than +4.3 C is actually a negative charge and therefore -4.3 C would be a positive charge.
Is this right or do i have it backwards and by stating +4.3 C they mean a proton charge (positive charge)?
You have it backwards. 1.602*10^-19 C is the magnitude of the charge on the electron (or proton). The sign of an electron's charge is negative.
A charge of +4.3 C is a positive charge--just as you'd expect!
No, one electron has a charge equal to -1.602x10-19 C. However, the elementary charge, which is assigned the symbol e has a charge equal to +1.602x10-19 C. Therefore, a proton has a charge of +1e and an electron of -1e. Does that make sense?
Edit: Doc Al strikes again...
Yes, thanks
