Cylinder attached to a block on an inclined plane, rotational dynamics
A cylinder with mass M and radius R rolls down an inclined plane while pulling a block of mass Mb, with the system's motion affected by friction and gravity. The moment of inertia for the cylinder is given as I_c = 1/2 MR^2. The challenge is to derive the linear acceleration of the system, considering the forces acting on both the cylinder and the block. A proposed solution for the linear acceleration is a = 2g[(M + Mb)sinθ - μMbcosθ] / (3M + 2Mb). Participants in the discussion suggest drawing free body diagrams to clarify the forces involved and help in solving the problem accurately.
jsrev
A cylinder of mass M and radius R, with moment of inertia:
I_c = \frac{1}{2}MR^2
rolls down without slipping through an inclined plane with an angle of θ, while pulling a block of mass Mb with an attached frame (of insignificant mass) which is connected to the axis of the cylinder.
If the cylinder rolls without slipping over the surface and the coefficient of kinetic friction between the block Mb and the surface is μ, then:
a. Deduct an expression for the linear acceleration of the system.
This problem didn't come with a figure, but I made one based on what I think the system looks like.
See figure http://imgur.com/HyiUSLu
Linear acceleration
I've tried a few ways, like calculating the linear acceleration of each object (the cylinder and the block) but there are some things I don't get.
I have tried calculating
a_{cylinder} = \frac{gsinθ}{k}
given that k is a constant that equal 1/2 from the first equation. Then I got the linear acceleration of the block with a_{block} = gsinθ and also considered the friction, but I'm not any close to the answer.
The given solution is:
a = \frac{2g[(M+M_b)sinθ-μM_bcosθ]}{3M + 2M_b}
If anyone can guide me a little bit in this one I would really appreciate it. Thank you.
Linear acceleration
Draw a free body diagram for the cylinder, and one for the block.
Here's your image:
See post 4
dean barry
Sorry, made a hash of that, here's the revised effort :
Assuming its a homogenous cylinder, then the equivalent mass (Me) of the non slipping cylinder for acceleration calculation purposes = 1.5 * M
(kg)
The total mass (Mt) being accelerated = Me + Mb
(kg)
The force due to gravity driving the system = ( M * g * sine θ ) + ( Mb * g * sine θ )
(Newtons)
The drag force of the block = Mb * g * cosine Ѳ * µ
(Newtons)
So :
The net force (fn) driving the system :
fn = ( ( M * g * sine θ ) + ( Mb * g * sine θ ) ) - ( Mb * g * cosine Ѳ * µ )
The acceleration (a) of the system = fn / Mt
So :
a = ( ( ( M * g * sine θ ) + ( Mb * g * sine θ ) ) - ( Mb * g * cosine Ѳ * µ ) ) / ( Me + Mb )
Comments ?
deanbarry365@yahoo.com
(kg)
What?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
