What is the value of b for a damped harmonic oscillator with given parameters?
To determine the damping coefficient b for a damped harmonic oscillator, the discussion begins with the parameters of a block, spring, and damping force. The initial amplitude is 28.5 cm, which reduces to 0.721 of its original value after 7 oscillations. The period of oscillation is calculated as 3.23 seconds, but there is confusion regarding the correct application of this value in relation to b. The energy lost during the oscillations is calculated to be 0.2 J, with a formula involving the natural logarithm of the retained energy percentage. Clarification is needed on the relationship between the damping coefficient and the period of oscillation.
Jrlinton
A damped harmonic oscillator consists of a block (m = 2.72 kg), a spring (k = 10.3 N/m), and a damping force (F = -bv). Initially, it oscillates with an amplitude of 28.5 cm; because of the damping, the amplitude falls to 0.721 of the initial value at the completion of 7 oscillations. (a) What is the value of b? (Hint: Assume that b2 << km.) (b) How much energy has been lost during these 7 oscillations?
so first to find the period
T=2pi(m/k)^0.5
=2pi(2.72kg/10.3N/m)^0.5
=3.23 seconds
I know that this will be used in finding b, along with the mass, but I am clueless where to go from here. Part b was much easier to figure out with the energy lost being 0.2 J
I know the equation is (2m*ln(x))/(T*oscillations). Is the ln(x)=ln(1/%of energy retained)?
T=2pi(m/k)^0.5
That is not the period of the oscillations. (It would be if b=0).
