DC Drive rating to run DC Shunt Generator
To run a 2.5 KW DC shunt generator, a DC motor with an appropriate horsepower rating must be determined, factoring in motor efficiency and losses. The conversation highlights the importance of understanding the conversion between horsepower and kilowatts. Additionally, the discussion raises questions about the power source for the motor and the load that the generator will be supplying. These considerations are crucial for accurately sizing the motor to ensure optimal performance. Overall, the efficiency and application context are key to determining the necessary motor specifications.
Ramachandra Rao KN
What HP of DC Motor is required to run a 2.5 KW DC Shunt Generator?
You're familiar with conversion of horsepower to kilowatts?
Yes
You may need to consider the losses in the motor (its efficiency) while calculating the required motor rating for your generator.
I am curious to know where this is going. What powers the motor and what is the generator powering?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
