DC motor start-up surge is tripping the battery protection circuit - help
The discussion revolves around a problem with a DC motor startup surge tripping the battery protection circuit of lithium batteries. The user experiences intermittent shutdowns due to the high initial current draw, which the protection circuit interprets as a short circuit. They have tried various solutions, including adding a digital voltmeter and a capacitor, but these either do not work or create additional issues. A suggested solution is to use an NTC thermistor in series with the motor, which initially limits current due to its high resistance and then allows more current as it heats up. The user finds this suggestion promising and plans to order the thermistor for testing.
-soapy-
Hi all,
I've got a problem which is so daft it hurts.
I'm using lithium batteries, and I'm well aware of the dangers, so despite being fine with working on an un-protected cell, I changed to protected ones, and then issues appeared. The current is drawn from a pair of parallel 18650's, good for about 6A continuous.
So, my circuit is incredibly simple - a DC motor, a switch and a battery. But because of the battery protection circuit, and the start-up current surge of the motor under the load, it simply shuts the battery power off. It does this shut-down in 12ms, which I've worked out after buying an expensive digital 'scope, and it stays off until you take away the "short circuit".
Sometimes it fires up, sometimes not. If I add a DVM to the circuit to measure the current, it also works perfectly. I think this is due to the resistance of the leads. If I add a power resistor it simply cooks that, and doesn't turn the motor. I've tried a 1mF cap to smooth it, but that gives another issue, in that if you manage to press the switch "just so" it dies and stays dead, as the cap keeps the battery protection on!
What I need is some (possibly mythical) part that will sit in the circuit and be a small resistor (an ohm) for a fraction of a second, then become a bit of wire (milli-ohms) until the switch is let go. Oh, and just to make it even harder, there is only a 10mm diameter by 35mm long space to fit anything inside the case!
I know this can be done, I know the current draw is safe, I know that it sometimes helps if I tweak the lengths of the leads a bit (though I don't understand quite how or why, it might be inductance or it might be resistance) - so please, if anyone knows what I should be looking at adding, please let me know!
I can post as much detail as you like, if you need any more. I've trawled Google, asked friends who might know, tried endless fiddling. It's killing me!
Thanks.
I've had a read up on them, it's rather interesting, they use a crystal of an exotic material that drops it's resistance with increasing temperature. That temperature is caused by the current through the device.
Very clever. Thanks for the suggestion, I'll get some ordered in the morning.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
