Solving triple integrals in a tetrahedron: How do I get started?
To solve the triple integral of f(x,y,z) = 2x + 3y over the tetrahedron bounded by the coordinate planes and the plane 2x + 3y + z = 6, begin by sketching the solid and its projection on the x-y plane. Rearranging the plane equation for z gives z = 6 - 2x - 3y. The limits for the innermost integral with respect to z are from 0 to 6 - 2x - 3y. The second integral with respect to y has limits from 0 to 2 - (2/3)x, and the outer integral with respect to x ranges from 0 to 3. The final setup for the triple integral is integral (x=0 to 3) integral (y=0 to 2-(2/3)x) integral (z=0 to 6-2x-3y)(2x+3y)dzdydx.
Dx
Compute triple integral f(x,y)dV given f(x,y,z)=2x+3y. T is the tetrahedron bounded by the coordinate planes and first octant part of the plane with equation 2x + 3y + z = 6.
how do i solve for this, can someone get me started halfway, please?
Dx
Mathematics news on Phys.org
I don't know if you have solved this problem already, but here goes:
The first step you will want to do is draw two diagrams, one of the solid, and one projection of it on the x-y plane.
Then solve the equation for z (or x or y whichever is going to produce the easiest integral outcome).
In this case I would go for the z solution:
z=2x+3y-6
Then determine the axis intersections in order to find the integral limits.
Set up your triple integral, solve.
The "innermost" integral will be with respect to z (dz) and will have limits z= 0 to z= 6- 2x- 3y.
"projecting" down to the x,y plane (z= 0) gives the line where the plane 2x+ 3y+ z= 6 crosses the x,y plane: 2x+ 3y= 6. We need to integrate over the triangle with edges x=0, y=0, 2x+ 3y= 6.
Solving for y, y= 2- (2/3)x. The second integral will be with respect to y (dy) and will have limits y= 0 and y= 2-(2/3)x.
Finally, project to the x-axis itself. The line 2x+3y= 6 crosses the x-axis when y= 0: 2x= 6 or x= 3. The final integral will be with respect to x (dx) and will have limits x= 0, x= 3.
The triple integral you want is
integral (x=0 to 3) integral (y=0 t0 2-(2/3)x) integral (z= 0 to 6- 2x+3y)(2x+3y)dzdydx.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
