Deriving the energy density of the Electric Field
The discussion revolves around solving a problem involving the electric field of two protons and calculating the energy density of the electric field. The user initially applied Coulomb's Law and attempted to break down the components for integration but faced challenges with the angles and messy expressions. Suggestions were made to simplify the dot product using the angle between the vectors and to correctly identify the total electric field's energy density. The conversation highlighted the distinction between interaction energy and self-energy contributions, with the user eventually finding a solution using Mathematica for integration. The thread emphasizes the importance of understanding the mathematical relationships and simplifications in electrostatics.
KvGroOve
Taken from Purcell Problem 1.33
Consider the electric field of two protons a distance b apart. The potential energy of the system ought to be given by
U=∫E2dv.
Let E1 be the field of one particle alone and E2 that of the other. Evaluate
ε0E1E2dv.
Set one of the protons at the origin and the other on the polar axis. Perform the integration over r before the integration over θ. Show that the integral has the value e2/4πε0b.
2. Homework Equations
I uploaded my attempt. I started by applying Coulomb's Law for Electric Fields to both protons. I broke down r1 and r2 into their Cartesian components to perform the dot product between the two. Since the two charges were both on the Polar Axis (I think I chose the right axis), I set φ12. I assumed that r1=r and θ1=θ. I eventually got an expression involving r22 and Cos[θ2-θ]. I was able to rewrite r22 using the law of cosines. I have no idea how to address θ2. I figured that I could use the law of sines to figure it out but the expression turns out to be really messy. I'm not really sure if I'm on the right track or if I've made an error anywhere.
Any advice regarding my mistakes and/or pointing me in the right direction would be much appreciated! Thanks.
Notice that your ##\theta_2 - \theta_1## is just the angle ##\beta## between the two position vectors. You could have gotten your final expression for ##\mathbf r_2 \cdot \mathbf r_1## more easily by thinking of the dot product in terms of the angle between the vectors.
Your idea of proceeding with the law of cosines and the law of sines sounds good to me.
##\cos \beta## will simplify fairly nicely in terms of ##\theta##, ##r_1## and ##r_2##.
Likes KvGroOve
Something seems funny to me. The total electric field is ##\mathbf{E_{T}}=\mathbf{E_{1}}+\mathbf{E_{2}}## so the energy density of the field is
$$u=\frac{\epsilon}{2}|\mathbf{E_{T}}|^{2}=\epsilon\left[\frac{1}{2}E_{1}^{2}+\frac{1}{2}E_{2}^{2}+\mathbf{E_{1}}\cdot\mathbf{E_{2}}\right]$$
not
$$u=\mathbf{E_{1}}\cdot\mathbf{E_{2}}$$
as shown in the problem. Are you actually finding the energy of the electric field or do you just need to solve the integral they gave you?
Likes KvGroOve
The E12 and E22 contributions are "self-energy" contributions which are infinite for point charges. A physicist just sweeps these under the rug :blushing:. The dot product part is the energy of interaction.
Likes KvGroOve and NFuller
I finally got it. I don't think I did it elegantly because I had to use Mathematica to help me solve an integral. Regardless, thanks for your help, TSny!
OK. Good. To do the r integration, you can do a substitution letting u be the expression inside the ( ... )3/2 in the denominator.
Likes KvGroOve
Wow. That makes it such a trivial integral to solve - I can't help but to laugh. Thanks again!
