Can Experimenting with Different Materials Help Understand Heat Retention?
In summary, Kruger and In summary, Kruger suggest doing an experiment involving measuring the rate of heat flow for different material to see if density effects the material's ability to retain heat. In addition, In summary, In summary, suggests doing a thorought analysis before designing the experiment.
courtney
Hi I am a year 12 student from Australia and I have to design an experiment. I have no idea what to do. Design is not my forte. I was thinking perhaps I could test whether density effects a material's ability to retain heat by testing the temperature change of a mass of water in a paper cup, plastic cup and foam cup. Would this work? What would I write about in my discussion? Help, please?!?
Experimental design involves calculating the range of observational results which will affirm or refute a prediction. This is done by quantifying the error terms of the detection devices with respect to the accuracy of results necessary to resolve the difference between a hit and a miss prediction.
Thank you for your help but I don't actually have to perform the experiment I merely have to design it. It must make sense and must have relevant background information to support it. I came up with the idea and have spent many hours doing research but to know avail. Nothing I have found has confirmed for me that my idea is a reasonable one to test. Is it reasonable? And if so where can I find the logical and relevant background information to support my theory and designed experiment?
Why not do something involving electromagnets.
Perhaps test Faraday's law.
That would be reasonably simple to do with the equipment your school has.
Or do something with the single or double slit experiment. You know, light will diffract, also electrons.
Hi. Thank you both very much for your suggestions. I didn't really want to change my topic this late in the game because I already have once (my teacher told me my initial experiment was a great idea so I finished the assignment and handed it up early and lucky I did because he said "I know I approved it to begin with but I don't think testing the specific heat of coffee will work because it is too complex a molecule". So I had to start again with two days to go! Fortunately I obtained an extension over the weekend so I'll be starting and finishing something that initially took me three weeks just to decide on the topic today!) I actually enjoyed the section on electromagnets very much so I am going to look into that one and see what sort of depth it will involve for the research information and the discussion (because that's where the real marks for the assignment are). So thank you for your help. And Kruger I liked your suggestion too but we have actually done a lot of single and double slit experiments in class during that unit of work and I know my teacher would appreciate it if we steered clear of anything remotely similar to class work but thanks anyway.
I have had another idea. Can I test the conservation of momentum of a tennis ball, a golf ball and a basketball when thrown against a wall using a stroboscope to show that the velocities are the same but in opposite directions? Is that a fair experiment?
Wow, you're already doing all the fun stuff! I wish I've done something like that when I was at your age!
I particularly liked your first proposal where you measure the rate of heat flow for different material to see if the density matters. Actually such thing would be easy to perform since all you got to do is measure the temperature difference. But I still recommend that you do a thorought analysis before designing it. For example, if you're trying to test the difference in rate of heat flow due to the different density, you must use same objects or materials with different density!
Good Luck
What is design investigation?
Design investigation is a systematic process of researching, analyzing, and evaluating various design options and solutions in order to develop the most effective and efficient design for a specific project or problem.
Why is design investigation important?
Design investigation is important because it allows for a thorough understanding of the problem or project at hand, and helps to identify potential design flaws or limitations. It also allows for the exploration of various design options and solutions, leading to a more effective and efficient final design.
What are the steps involved in a design investigation?
The steps involved in a design investigation typically include problem identification, research and analysis, concept development, prototyping and testing, and final design selection and implementation. However, the specific steps may vary depending on the project and the design process being utilized.
What are some common tools and methods used in design investigation?
Some common tools and methods used in design investigation include brainstorming, sketches and drawings, computer-aided design (CAD) software, prototyping, user testing, and data analysis. Additionally, various research methods such as surveys, interviews, and focus groups may also be used.
How does design investigation differ from other design processes?
Design investigation differs from other design processes in that it involves a more thorough and systematic approach to understanding and solving a design problem. It also places a strong emphasis on research and analysis, as well as prototyping and testing, in order to develop the most effective and efficient design solution.
  • Materials and Chemical Engineering
  • Thermodynamics
  • Nuclear Engineering
  • Electrical Engineering
