Determine stopping distance of a train traveling at 20m/s
A train traveling at 20 m/s is brought to an emergency stop with a time-dependent acceleration of a = -(7/4) + (t/16) m/s². Using Euler's method with Δt=2s, the calculated stopping distance is between 150.5 m and 152 m, which exceeds the analytically determined distance of 138.7 m. Discussion includes the application of linear interpolation to refine the stopping distance estimate, with a suggested calculation yielding approximately 151.14 m. However, it is noted that the Euler method introduces an error of about 3.5 m in the first step. The conversation emphasizes the importance of accuracy in numerical integration methods for determining stopping distances.
Alexanddros81
This is problem 12.81 from Pytels Dynamics 2nd edition
1. Homework Statement
A train traveling at 20m/s is brought to an emergency stop. During braking,
the acceleration is a=-(7/4)+(t/16) m/s^2, where t is the time in seconds measured
from when the brakes were applied. (a) Integrate the acceleration from t=0 to
t=16s using Euler's method with Δt=2s. (b) Use the results of the integration to
determine the stopping distance of the train and compare you answer with 138.7m,
the value found analytically.
[/B]
According to the results of the Euler method above the stopping distance is between 150.5-152 m
That is way above 138.7m. Am I correct?
Looks good to me.
Is the stopping distance between x7 and x8 where the velocity is 0?
Do I use linear interpolation to find the stopping distance?
for example:
Do I use something like this?
If yes how do I apply linear interpolation in above graph to find x?
You could do that, but as you see there is little gain in accuracy (*)
You would use something like $${x-150\over v_7} = {x-152\over v_8} \Rightarrow x = \left ( {150.5\over v_7}-{152\over v_8} \right )/ \left ({1\over v_7}-{1\over v
_8}\right ) $$ or 151.14.
(*) the error the Euler integration makes in the first step is already about 3.5 m
( ## x = v_0 t -{1\over 2} a_0 t^2 \ ## gives 36.5 m instead of 40 m, the exact formula ##v_0 t - {1\over 2} {7\over 4} t^2 + {1\over 2}{1\over 3} {\displaystyle t^3\over 16} ## gives 36.6 m )
