Determine the speed of the smaller mass
  • Thread starter Thread starter Gughanath
    Mass Speed
To determine the speed of the smaller mass after sliding down the incline, first calculate its velocity at the bottom using energy conservation principles, converting potential energy to kinetic energy. For the elastic collision with the larger mass, apply the conservation of momentum and kinetic energy to set up simultaneous equations. The initial speed of the smaller mass can be derived from its height and angle on the incline. After solving the equations, you can find the final speeds of both masses post-collision. Understanding these principles will clarify the process of solving the problem.
Gughanath
A block of mass m = 2.30 kg slides down a 30.0° incline which is 3.60 m high. At the bottom, it strikes a block of mass M = 7.10 kg which is at rest on a horizontal surface, Fig. 7-41. (Assume a smooth transition at the bottom of the incline, an elastic collision, and ignore friction.)
How can I determine the speed of the smaller mass and the greater mass after the colision. This is really confusing me :confused: . please help
In an elastic collision, momentum and kinetic energy are conserved for the system.
So from this I should be able to make a simultaneous equation?
