Determine the time the arrow is in flight
  • Thread starter Thread starter candycooke
    Flight Time
To determine the time the arrow is in flight and the angles for a 30-meter distance, two equations involving the angle (θ) and time (t) must be established. The initial speed is 25 m/s, and the vertical motion equation should account for the highest point where the vertical velocity (v_fy) is zero. The correct equation for time in the y direction is t = 2(0 - 25sinθ)/-9.8 m/s², while the horizontal motion equation is t = 30 m/(25cosθ). The confusion arises from incorrectly solving for time and not considering the symmetrical nature of projectile motion. Understanding these equations will lead to finding both angles at which the arrow can be aimed.
candycooke
An arrow is shot with an initial speed of 25 m/s (and lands at the same height as its launch height). There are two possible angles at which it chould be aimed so that it goes 30 meters. What are they?
Givens:
v(i)=25m/s
a=-9.8m/s^2
d(x)=30m
I know the first step is to determine the time the arrow is in flight, but I'm not exactly sure which formula to use in order to find time.
In this problem you have two unknown variables, the angle,\theta, and the time, t. You need to find two equations involving both of those variables, then you can solve for both of them.
HINT:
You have motion in two directions here. Can you set up an equation of motion for each direction involving \theta and t?
since the porabola is symetrical, than v(i)=v(f)
for y components:
t=v(f)-v(i)a
=0a
for x components:
t=d/v
=30m/25cos\theta
therefore:0=30m/25cos\theta
\theta=33.6
So I've figured out one angle but I am unsure how to determine the second possible angle.
Your equation for the x direction is correct. Leave it as is.
Your equation for the y direction of motion is wrong. Think about what it says. How can the arrow take 0 seconds to make it's trip?
You solved for t incorrectly. Check your work. Also, I suggest using the highest point as your final point in the y direction. (Why you ask? What is v_fy at the highest point?) Remember that the arrow will hit it's highest point at t/2 seconds, where t is the time of the whole trip.
Since v_fy=0 at the highest point:
t/2=(0-25sin\theta)/-9.8m/s^2
therefore:
t=2(0-25sin\theta)/-9.8m/s^2
but this is not equal to t=30m/(25cos\theta)
I am so confused.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
