Determining direction and magnitude of electric field in a ring.
The discussion focuses on determining the direction and magnitude of the electric field at the center of a charged ring with a varying charge distribution described by λ(θ) = λ₀sin(θ). It is established that the electric field at the center of the ring points outward, but due to symmetry, the net electric field at that point is zero. Participants suggest using symmetry to analyze the contributions of small charge elements around the ring, emphasizing that opposite charges will produce equal and opposite electric field vectors that cancel each other out. The calculations involve integrating the electric field contributions, but confusion arises regarding the correct form of the charge distribution in the integral. Overall, the key takeaway is that the symmetry of the charge distribution leads to a zero net electric field at the center of the ring.
stripes
A ring of radius a has a charge distribution on it that varies as \lambda(\theta) = \lambda_{0}sin \theta. a.) What is the direction of the electric field at the center of the ring? b.) What is the magnitude of the field at the center of the ring?
The textbook includes a picture of a ring/circle with radius a, angle \theta, and charge distribution \lambda. It's pretty basic and straightforward.
Only one that I can think of:
E_{z} = \frac{kQz}{(z^{2} + a^{2})^{3/2}}
I really don't know where to start. I mean I don't have any value for anything (other than if I were to just manipulate my given function and put it in the equation in "Relevant equations"), and z isn't even given in my function. I'm not understanding the picture (sorry I couldn't post the picture on here); it shows basically a circle with its radius forming an angle between the radius and the x axis. I really can't relate that to how this question is worded.
Since I haven't really attempted anything, I'm not looking for someone to do my homework, but rather, for some hints and suggestions.
Thank you all in advance!
Some hints. On your diagram, sketch the charge at various points along the circle. You should be able to answer (a) without any calculation. Use symmetry.
Instead of trying to find a canned formula, you'll have to come up with your own. Consider a small element of the charged ring. What field does it produce at the center? Again, use symmetry.
Alright, well after some thought, here's what I've got.
E = \int dE<br /> <br /> = \int \frac{kdq}{a^{2}}<br /> = \frac{k}{a^{2}}\int dq
after a little manipulation and substituting:
\frac{k}{a^{2}}\int a\lambda^{2}d\theta<br /> = \frac{k}{a}\int \lambda^{2}_{0}sin^{2}\theta d\theta
bring lambda-not out of the integrand, and we get:
= \frac{k \lambda^{2}_{0}}{a}\int sin^{2}\theta d\theta
but after I noticed another thread on this same question here at PF, I noticed the answer shouldn't have theta-not squared, it should just be theta-not...what went wrong there? Other than that, are my steps correct and the resulting formula for E correct?
or, i think I might have put in the squared by mistake...instead would it just be:
<br /> = \frac{k \lambda^_{0}}{a}\int sin\theta d\theta<br />
What did you get for (a)?
well, the field will point outwards, from the ring, and thus in the middle, there is zero field. So the direction points outwards from the ring.
I don't understand how you arrived at this conclusion. Take several small segments of the ring and see which way their field points at the center of the ring. (Getting part a straight will help with part b.)
I think the good Doc wants you to look at the symmetry between the various E-field vectors produced by various charges around the circle. Symmetry can help you cancel some stuff and make the problem easier.
Argh...I'm so confused...
I mean it just seems like on any given point on the ring, the point opposite of it would have the same magnitude. Like charges repel, so the fields would all point outwards from the ring. That's what I thought...
I think I'm going to read my textbook and go over this stuff again. After that, I'll come back on here and go from there.
The same magnitude of E-field contribution, Yes it would and would also be pointed in the opposite direction...
And you are not looking at the Force of one charge on a charge opposite of it in the circle. You are looking at the contribution of a bunch of point charges that are arranged in circle to an E-field at a certain point in space. And that point in space happens to be right in the middle of the ring of charge.
