Determining Minimum Height for Marble to Complete Loop-the-Loop
The problem involves a marble rolling down a track and around a loop-the-loop, with the goal of determining the minimum height required for the marble to complete the loop without falling off. The context includes concepts from energy conservation and rotational dynamics.
  • Participants discuss energy conservation principles, including potential and kinetic energy at different points in the motion. There are attempts to calculate the initial and final energy states, with some questioning the inclusion of rotational kinetic energy in the calculations.
The discussion has seen various interpretations of the energy calculations, with some participants suggesting reconsideration of specific terms in the energy equations. There is acknowledgment of the complexity introduced by the marble's radius and its effect on the center of mass during the loop. One participant indicates they have resolved their confusion after considering these details.
Participants note the importance of accounting for the radius of the marble when determining the effective radius of the loop, which affects the calculations. There is mention of the need to clarify the relationship between linear and rotational motion in this context.
kamikaze1
A marble rolls down a track and around a loop-the-loop of radius R. The marble has mass m and radius r. What minimum height h must the track have for the marble to make it around the loop-the-loop without falling off?
Find initial energy: mgh
Final energy tabulation: mg(2R) + 0.5mrg + 0.5(2/5)mr^(2)(v/r)^2
Set equal to initial energy, I obtain 2R+7/10 =h, which isn't the right answer, what did I do wrong?
I found the velocity at top by using Newton's 2nd law, i get v = squareroot(rg). I find w using constraint of wr=v. I get 2/5(mr^2) using moment of inertia for a solid sphere.
Any help would be appreciated. I'm so confused why this doesn't work out.
I'm still new to this, but it looks like you've got everything right except for the last part of your final energy calculation (the 0.5(2/5)mr^(2)(v/r)^2 part). I'm not quite sure why it's there, but I'm pretty sure that's the part that's throwing you off.
The last part is the kinetic rotational energy using I = (2/5)(M)(R^2)
Using kinetic rotational energy = 0.5Iw^2, I have
0.5(2/5)(MR^2)w.
using constraint wr=v, knowing that v=(rg)^0.5, I get
The answer isn't right.
The energy at the top of the loop is the potential (which you have) plus it's kinetic, since it is moving in a circle there must be an acceleration at the top equal to [itex]\frac{V^2}{R}[/itex], for this to be a minimum (IE only just making it around the loop) this acceleration must be set equal to [itex]g[/itex] so we have
[tex]V^2 = gR \Rightarrow KE = \frac{1}{2}mgR[/tex]
[tex]\displaystyle{\dot{. .}} mgh = mg(2R) + \frac{1}{2}mgR[/tex]
Which you can then solve for the minimum height :)
EDIT: Just reread your question, the "effective" radius of the loop is changed because of the radius of the marble (the center of mass of the marble moves around a slightly smaller loops) and there is indeed rotational energy equal to [itex]\frac{1}{2}\frac{2}{5}\frac{gR}{r^2}mr^2[/itex] (again this has to be changed because the [itex]R[/itex] isn't really the radius of the loop that the center of mass moves over, but I'll leave that to you)
Never mind. Thanks for all your suggestions. I've just solved them. I left out the little tiny details which messed up the problems. I didn't take into account of the center of mass, which I paid dearly.
Here is how I solved it.
Initial energy: mg(h+r)
At the loop, the radius is R-r because we're taking into account of the center of mass. Hence using Newton's 2nd law.
m(v^2)/(R-r) = mg, solve for v = (g(R-r))^0.5 (1)
Final energy at top of the loop is:
mg(2R-r) + 0.5(m)(g(R-r)) + 0.5(2/5)(mr^2)(w^2).
Using velocity constraint, w=v/r=(1/r)(g(R-r))^0.5
Plug that in (1), and set (1) equal to initial energy, then solve for h.
13K
16K
