Determining pressure at equilibrium with Kp
To determine the equilibrium pressure of O2 in the reaction 4 Fe3O4(s) + O2(g) <----> 6 Fe2O3(s) with Kp = 2.5 x 10^87, the equilibrium constant expression should only include gases. The correct formulation for Kp is Kp = P(Fe2O3)^6 / P(O2), leading to the conclusion that P(O2) must be calculated as 1/(Kp^(1/2)). The user initially miscalculated the pressure, leading to confusion regarding significant digits and the correct application of the equilibrium constant. Clarification on the proper use of Kp and significant figures is essential for accurate calculations.
Emworthington
The minerals (Fe2So3) and (Fe3O4) exist in equilibrium with atmospheric oxygen.
4 Fe3O4(s) + O2(g) <----> 6 Fe2O3(s) kp = 2.5 x 10^87
Determine P(O2) at equilibrium
Since the equilibrium constant can only have gases in it, I assumed that the equation would be
1/[O2]^2 so that the pressure would be 1/2.5*10^87. However, it's an online program and says that that (4*10^-88) is wrong. It also says that 2.5*10^87 is wrong. What else do you think I could do?
No idea why 1/[O2]2 and not just 1/[O2], but perhaps that's just a typo.
Some of these HW programs are very anal about significant digits.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
