Diameter of imperial machine screws
The discussion centers on understanding the diameter and thread specifications of imperial machine screws, specifically the notation used on a website. Users clarify that the first number in the designation, such as "2-56," indicates the screw size and the second number represents the threads per inch (TPI). The user is looking for a 5/32 inch diameter screw, which is not a standard US size and may correspond to a rare #7 screw. Additionally, there is mention of the need for accurate measurements and potential confusion with British sizing. The conversation concludes with a confirmation of the thread size definitions, aiding the user's understanding.
temujin
Dear Forum,
I am currently trying to buy some imperial machine screws and bolts online, and I am confused with how the diameter is given.
The website I am seaching (boltdepot.com) gives me these diameters but I don´t understand what is meant by i.e. "2-56"
2-56
4-40
6-32
8-32
10-24
10-32
12-24
1/4-20
5/16-18
3/8-16
1/4-28
Can anyone help me? I am specifically looking for a 5/32 inch diameter screw but this does not appear here. Anyone suggesting a different good site for buying fasteners online, preferably located in europe?
best regards
t.
Below a 1/4" they are just given numbers, a #8, #10 etc - the diameter is d=0.06" + (#*0.13")
or you to look up the diameters in a machinist handbook
Above 1/4" the first number is the diameter of the bolt in inches.
In both cases the second is the number of threads per inch, so a 'quarter-20' is 0.25" diameter and a thread pitch of 0.05"
5/32 isn't a standard US size, it's almost a #7 - which is also rare.
Is this an old British part ? in Which case it might be whitworth.
Thanks,
It is definitely an US part.
My local store here thought it was a 5/32 and I believed them. Might even be a #7 as you say. I probably need to measure it myself...
Edit:
With respect to the list in my first post, does 2-56 then mean screw #2 with 56 threads per inch? and "4-40" is #4 with 40 tpi?
regards
t.
Correct - I clarified my post a little
Thanks.t
This helped a lot.
t.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
