Did I do this coversion to Standard correctly?
  • Thread starter Thread starter trigger352
    Standard
The discussion focuses on converting the equation 4x^2 - 9y^2 + 32x + 18y + 91 = 0 into standard form. The initial steps involve completing the square for both x and y terms, but errors are noted in handling the constant terms. A participant realizes that when moving constants across the equation, they must account for their signs and the factors involved. The correct balancing of constants is crucial to ensure the equation remains valid, and there is a mention of needing to divide the entire equation by 36 to achieve the correct denominators. The conversation emphasizes careful attention to detail in algebraic manipulation to avoid mistakes.
trigger352
Cover to standard form...
4x^2 + 32x.....-9y^2 + 18y.....+91 = 0
4(x^2 + 8x + 16)...-9(y^2 - 2y + 1)...+91 -16 -1 = 0
4(x + 4)^2.....-9(y - 1)^2.....+74 = 0
therefore
\frac{(y - 1)^2}{4} - \frac{(x+4)^2}{9} = 74
You made a few errors with the constant terms. See if you can figure out where.
therefore
When the 74 goes over the = it becomes a negative, which is not possible. So, I'm thinking i did something wrong by dividing out -9. Somehow I need to get a balancing number that is larger that 91 so it won't be positive on the other side... :confused:
But I do see something that might work...
I have to change those balancing numbers. I only countered the -16 and -1. But those weren't multiplied by that factor.
Ok, So, 91 - 64 + 9 = 36. 36?
But I can't get a positive number...since when it goes over the = line it'll be negative.
36 is correct. The negative is no problem: just multiply both sides by -1.
You made one more mistake though. To get the 4 and 9 in the denominators you had to divide the equation by 36. Do you see anything that you missed?
