Dielectric Problem: Q&A to Calculate Electric Field & Induced Charge
  • Thread starter Thread starter at3rg0
    Dielectric
The discussion revolves around a problem involving two parallel plates with charges Q and -Q, examining the effects of a dielectric material on the electric field between the plates. The original poster seeks to determine the dielectric constant and the area of the plates, given specific electric field values in different conditions.
  • The original poster attempts to calculate the area of the plates using various equations related to capacitance and electric fields, but expresses uncertainty about missing information. Some participants suggest showing calculations for clarity and question whether the plate separation distance is provided.
  • Participants discuss the rearrangement of formulas to derive the area, with one participant questioning the units involved in their calculations and another confirming the correctness of the unit analysis.
  • There is a focus on the relationship between charge, electric field, and area, with attempts to clarify the manipulation of equations to arrive at the correct area measurement.
Participants note the absence of certain information, such as the plate separation distance, which may be relevant for solving the problem. There is also a mention of needing to convert units for the area calculation.
at3rg0
Two parallel plates have charges Q and -Q. When the space between the plates is devoid of matter, the electric field is 2.7E5 V/m. When the space is filled with a certain dielectric, the field is reduced to 1.3E5 V/m.
What is the dielectric constant of the dielectric?
I got this answer as 2.07692, which was correct.
If Q = 8 nC, what is the area of the plates?
I tried plugging the numbers into the formulas below, but I'm not getting the right answer...Am I missing a piece of relevant information?
What is the total induced charge on either face of the dielectric?
This will be easier once I figure out the second question.
E=E(not)/kappa
V=Ed
C=Q/V
C=epsilon(not)*kappa*Area/distance
I got the first answer, and the second I could not get.
It is more helpful to someone wishing to assist you if you show your calculation so they can see what you set up and what values you got. Thanks.
P.S. Are you given a plate separation distance?
Using the formulas, I got that
Area = Q*Epsilon(not)/Electric Field
So Area = (8E-9)(8.85E-12)/1.3E5 = 5.45E-25 m^2 (so 5.45E-23cm^2) - I need to give the answer in cm^2.
The units on the right hand side are presently (C)·(C^2/N·m^2)/(N/C), so I don't think this is going to give you an area.
OK, you don't need a plate separation, but I suggest you review how you rearranged your equations to get Area...
Going by units alone...
Shouldn't Q/(Epsilon0 * E) give m^2?
All right, I tried rearranging again.
A = C/(Epsilon0*E*kappa), which gives me .003762. Where am I making the mistake in formula manipulation?
I used C=Q/V, where V=Ed, and C=kappa*epsilon0*Area/d
This is fine now. You set
C = (kappa·eps0·A)/d = Q/V , so
A = (Q · d)/(kappa · eps0 · V) , but E = V / d , so
A = Q / (kappa · eps0 · E).
The units are C / [ {(C^2)/N·(m^2)} · {N/C} ] = C / [C/(m^2)] = m^2 .
I also get your value, but it looks small because it's in m^2, so A = 33.6 cm^2. (What are you using for epsilon_0 ?)
  • · Replies 17 ·
