Solving Word Problems: Heat in a Cylinder & Evaporation of a Sphere
Gale
my biggest problem is the word problems. i can't figure out how to write the equation so that i can do the math...
Heat is escaping at a constant rate (dQ/dt is constant) through the walls of a long cylindrical pipe. Find the temperature T at a distance r from the axis of the cylinder if the inside wall has a radius r=1 and a temperature T=100, and the outside wall has r=2 and T=0.
so i couldn't figure out how to model this. dQ/dt= C doesn't get you very far... maybe cause I'm not sure how to relate the heat to temperature.
then i had another problem:
A substance evaporates at a rate proportional to the exposed surface. If a spherical mothball of radius 1/2 sm has a radius .4cm after 6 months, how long will it take for the radius to be 1/4cm?
i started with like dS/dt= k(SA), where S is the amount of substance and SA was the surface area, (which for a sphere is dependent on r, so this was looking good) but then i got confused about whether i need a negative sign or what else because the substance is lessening. then i wondered if the negative would be just be inherent in the solution, cause it ought to be i thought... i don't know. I'm just getting confused.
I'm not a physicist, but I think if S is entropy then dQ = T dS.
You need a minus sign for your second equation because we want the rate of decrease of the substance, and not the rate of increase.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
