Difference in potential energy of two charge configurations
The discussion focuses on determining the smallest value of N such that the potential energy V1 of configuration C1 exceeds that of configuration C2, where C1 consists of N point charges uniformly distributed on a ring and C2 consists of N-1 point charges on a ring with one charge at the center. Through two approaches, the potential energies U1 and U2 are derived, leading to the conclusion that N must equal 12 for V1 to be greater than V2. The analysis highlights the complexity of electrostatic potential energy calculations in charge configurations.
  • Understanding of electrostatics and potential energy
  • Familiarity with Gaussian surfaces and electric fields
  • Knowledge of trigonometric identities and their application in physics
  • Ability to perform numerical methods for solving equations
  • Study the principles of electrostatic potential energy in charge distributions
  • Learn about Gaussian surfaces and their implications in electrostatics
  • Explore numerical methods for solving complex equations in physics
  • Investigate the properties of point charges and their interactions
Students and professionals in physics, particularly those focusing on electrostatics, computational physics, and numerical analysis of physical systems.
theideasmith
Chapter 24, Question 61
Given two configurations, ##C_1##, ##C_2## of ##N## point charges each, determine the smallest value of ##N## s.t. ##V_1>V_2##.
##C_1##:
##N## point charges are uniformly distributed on a ring s.t. the distance between adjacent electrons is constant
##C_2##:
##N-1## point charges are uniformly distributed on a ring s.t. the distance between adjacent electrons is constant and one charge is placed in the center of the ring.
Approach I
1. If we consider a gaussian surface inside the ring, ##E=0##. We know that the voltage at the center of the ring is $$V_\text{center}=\frac{Ne}{r}$$ and furthermore, because $V=\int E\circ ds$, $$V_\text{inside} = V_\text{center}$$
2. From this previous result, $$U_1 = eV_\text{center} = \frac{N(N-1)e^2}{r}$$
3. ##C_2##
the configuration potential without the center electron is $$(1/2)(N-1)(N-2)\frac{e}{r}$$ The center electron adds ##(N-1)\frac{e}{r}## yielding $$U_2 = (1/2)(N-1)(N-2)\frac{e}{r} + (N-1)\frac{e}{r}$$
4. Let ##k = \frac{e}{r}##, and, setting ##(N^2-N)k = (N^2-3N+2)k+(2N-2)k##
$$\implies 0=0$$
Approach II
Let ##N## charges be arranged along a circle with radius ##R##. The position of an arbitrary particle at an angle ##\theta## relative to the positive direction of the x-axis is ##\vec{P}(\theta) = (R\cos\theta, R\sin\theta)##. Pick one charge located at angle $\theta = \theta_i$ and another particle located at ##\theta = \theta_j## relative to the positive direction of the x-axis. The distance between the two particles ##\vec{r}## is
\begin{align}
\vec{r} &= \|\vec{P}(\theta_j) - \vec{P}(\theta_i)\| \\
&= \|(R\cos\theta_j, R\sin\theta_j) - (R\cos\theta_i, R\sin\theta_i) \\
&= \|R(\cos\theta_j-\cos\theta_i, \sin\theta_j - \sin\theta_j)\|\\
&= R\|(\cos\theta_j-\cos\theta_i, \sin\theta_j - \sin\theta_j)\| \\
&= R \sqrt{
\cos^2\theta_j -2 \cos\theta_j\cos\theta_i + \cos^2\theta_i \\
+ \sin^2\theta_j -2 \sin\theta_j \sin\theta_i + \sin^2\theta_i
&= R\sqrt{
1-\sin^2\theta_j +1-\sin^2\theta_i + \sin^2\theta_j + \sin^2\theta_i \\
-2(\cos\theta_j\cos\theta_i+ \sin\theta_j \sin\theta_i)
&= R\sqrt{
2-2(\cos\theta_j \cos\theta_i + \sin\theta_j \sin\theta_i)
&=R\sqrt{2(1-\cos\theta_j \cos\theta_i - \sin\theta_j \sin\theta_i) } \\
& = R\sqrt{2(1-\cos(\theta_j + \theta_i))}\\
\therefore \vec{r} &= R\sqrt{2(1-\cos(\theta_j + \theta_i))}
\end{align}
Where
\theta_k = k\Delta \theta \\
\Delta\theta = \frac{2\pi}{N}
We get
\begin{aligned}
\vec{r} =R\sqrt{2}\sqrt{1-\cos\left((i+j)\frac{2\pi}{N}\right)}
\end{aligned}
With this expression for ##\vec{r}##, we can write the net potential energy for particle ##j## along the circle with the equation assuming all particles have charges ##q##
\begin{align}
U_\text{particle i} & = \sum_{j=1, i \ne j}^{N}
\frac{q^2}{4\pi\epsilon_0R\sqrt{2(1-\cos(\theta_i + \theta_j))}}}\\
& = \frac{q^2}{4\pi\epsilon_0R\sqrt{2}}\sum_{j=1, i \ne j}^{N}
\frac{1}{\sqrt{1-\cos(\theta_i + \theta_j)}}} \\
& = \frac{q^2}{4\pi\epsilon_0R\sqrt{2}}\sum_{j=2}^{N}
\end{align}
we set ##j_\text{initial} =2## which is equivalent to the conditions ##j=1, j\ne i##
For concision, let
L = \frac{q^2}{4\pi\epsilon_0R}
Then net potential energy can be expressed as
\begin{align}
U(n)
& = \frac{1}{2}\sum_i^{n}U_i \\
& = \frac{L}{2} \sum_{i=1, j=2}^{n,n}
\frac{1}{\sqrt{2-2\cos(\Delta \theta(i+j-2))}}
&= \frac{nq^2}{8\pi\epsilon_0R}
\sum_{j=1}^{n-1}{
\frac{1}{\sqrt{2}\sqrt{1-\cos(j\Delta\theta))}}
\sum_{j=1}^{n-1}{
\frac{1}{\sqrt{2}\sqrt{1-\cos(j\frac{2\pi}{N}))}}
\sum_{j=1}^{n-1}{
\frac{1}{4\sin(\frac{j\pi}{N})}
&= \frac{nq^2}{32\pi\epsilon_0R}
\sum_{j=1}^{n-1}{
\csc\left(j\frac{\pi}{N}\right)
\end{align}
For two configurations with ##N## charges we define the potential energies:
U_1 = U(N) \\
U_2 = U(N-1) + (N-1)L
where the second term in the definition of ##U_2## determines the potential for the lone particle in the center.
Now we solve for the ##N## at which ##U_1 = U_2##
\begin{aligned}
U_1 - U_2& = \Delta U \\
&=N\frac{q^2}{32\pi\epsilon_0R}
\sum_{j=1}^{n-1}{
&+(1-N)\frac{q^2}{32\pi\epsilon_0R}
\sum_{j=1}^{n-2}{
\csc\left(j\frac{\pi}{N-1}\right)
& +(1-N)L
\end{aligned}
Which is really difficult to solve directly.
theideasmith said:
Given two configurations, ##C_1##, ##C_2## of N point charges each, determine the smallest value of ##N## s.t. ##V_1>V_2##.
Are ##V_1## and ##V_2## the electrostatic potential energies associated with each distribution?
How do you figure? The electric flux out of the Gaussian surface is zero, but this doesn't mean that the electric field everywhere must be zero as a result. For example, what if the configuration has N = 2?
After fixing up my algebra, I ended up with the equation
$$\begin{aligned}
U_2-U_1 &= 0 \\
&= L\frac{N-1}{2}\sum_{j=1}^{N-2}{\csc\left(\frac{j\pi}{N-1}\right)}
+ L(N-1)2
- L\frac{N}{2}\sum_{j=1}^{N-1}{\csc\left(\frac{j\pi}{N}\right)} \\
&= L\left(\frac{N-1}{2}\sum_{j=1}^{N-2}{\csc\left(\frac{j\pi}{N-1}\right)}
- \frac{N}{2}\sum_{j=1}^{N-1}{\csc\left(\frac{j\pi}{N}\right)}
+ 2(N-1)
\right)
\end{aligned}$$
and numerically solved for ##N## by plotting the series for ##U_1## and ##U_2##.
I got ##N=12##.
Lesson: Sometimes brute force is necessary.
Full solution: http://theideasmith.github.io/2017/02/14/Point-Charge-Configuration.html
  • · Replies 16 ·
  • · Replies 19 ·
