Different bandwidth for different devices
  • Thread starter Thread starter dannan14
    Bandwidth
A user is experiencing significant bandwidth issues on their PC, receiving less than half a Mbit when connected to a wireless router, while their phone achieves over 4 Mbit under the same conditions. The PC's embedded network interface card (NIC) was recently replaced with a USB NIC, which operates on 802.11n and connects via USB 2.0. This setup is causing poor performance, leading to buffering issues during video playback. Forum participants suggest that using a USB NIC is likely the root cause of the bandwidth problem, recommending the purchase of a traditional PCI NIC for better performance, as it is generally more reliable and efficient than USB alternatives.
dannan14
Hi, I'm trying to diagnose a bandwidth problem on my PC. I'm getting less than half a Mbit when connected to my house's wireless router. However, when i connect to that same router with my phone i get over 4Mb.
Both devices were tested on the same website (bandwidth place) so i am certain that the test results are on the same scale. On my PC videos will run for a few seconds, buffer for longer, then run for a few seconds, etc. On my phone the same video runs smoothly.
The embedded NIC in my PC recently died, so i replaced it with a USB NIC. The new NIC is 802.11n and it is connected to a USB 2.0. I'm at a loss for what i can do to correct this problem. Any ideas?
Thanks in advance for any help.
Computer science news on Phys.org
USB NIC is a bad idea. Performance will always be bad due to the nature of the USB setup.
Thanks for the input. Are you saying that it isn't worth my time to continue trying to make this product work as advertised? As in i should just buy a traditional card because there is no solution to this problem?
If you can buy a PCI card then by all means, it will give the best performance. They are pretty cheap these days.
i appreciate the advice, thanks!
Sorry if 'Profile Badge' is not the correct term. I have an MS 365 subscription and I've noticed on my Word documents the small circle with my initials in it is sometimes different in colour document to document (it's the circle at the top right of the doc, that, when you hover over it it tells you you're signed in; if you click on it you get a bit more info). Last night I had four docs with a red circle, one with blue. When I closed the blue and opened it again it was red. Today I have 3...
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
