Differential Equation for deceleration of a bullet
The discussion centers on modeling the deceleration of a bullet as it penetrates an amorphous plate, using Newton's Second Law. Participants explore the implications of friction being proportional to the bullet's velocity and the resulting differential equation. A key point is the realization that the bullet's motion approaches an asymptotic behavior, meaning it never fully stops but slows down significantly over time. The conversation also touches on the physical interpretation of the model, comparing it to a boat drifting after turning off its motor. Ultimately, the derived formula for the distance the bullet travels before stopping is confirmed as xf=v0*m/k.
Unsilenced
A bullet of mass m strikes an amor plate with initial velocity v0. As the bullet burrows into the plate, its motion is impeded by a frictional force which is directly proportional to the bullet's velocity. There are no other forces acting on the bullet.
-Use Newton's Second Law to set up an IVP for the position of the bullet
-How thick should the plate be to stop the bullet?
[None given with problem]
I attempted to use a modified version of a harmonic oscillator formula, where there is no spring. Only the momentum of the object and the friction force resisting it.
m*d^2x/dt^2-kdx/dt=0.
However, in solving it I've run into a problem. While I got an equation for x, x(t)=v0*e^Rt/(R-1)-v0/(R-1) (where R=m/k), trying to use that to find the time at which the bullet stops yields
0=v0*R*e^Rt/(R-1)
e^x=/=0, regardless of x, so there is no possible time at which dx/dt=0.
Is my model flawed, or have I made some other error?
Think about what that equation is saying. For a greater dx/dt, what happens to the acceleration?
Check your sign on the friction term ;)
Acceleration becomes more negative, that is, deceleration increases with velocity. So, I could make both terms negative?
Switching the signs in the initial equation only changes whether R is positive or negative. That doesn't solve the fact that my final equation is mathematically impossible.
Yes, but making them both positive is probably less confusing. For example, the equation of motion is:
F=ma=-kv
Now bring them to one side, set a=dv/dt and solve for v(t). Then integrate again to solve for x(t)
Yes, you will have a negative exponential which approaches 0 as time goes to infinity. You should be able to solve it from there.
Ah, I see. So it is meant to be asymptotic? I thought it might be, but it didn't make sense from a physical interpretation, I.E that the bullet never stops moving.
Yes unless I'm missing something. A better example may be a boat which turns off its motor. How far does it drift before stopping? In this case the asymptotic relation is a bit more realistic. With the bullet-wood example, the k value is much larger so it approaches 0 very quickly. It may help to think of the "wood" instead as being jello :)
Yeah, that does make it a bit easier to visualize. In the case of a bullet hitting a metal plate, the medium tends to be denser than the projectile, and all sorts of deformation occurs. In real life this equation would look a bit more like this: http://i.imgur.com/2KA5jiv.gif :p
A non-deforming projectile in a fluid medium makes the result a bit more logical. The result I ended up getting was
xf=v0*m/k
Seems legit.
xf=v0*m/k
Seems legit.
Yup that's what I calculated as well.
