Differential Equation Question
Ravi Ramdoolar
Felix, a Red bull skydiver, (mass m) who drops out of a hovering helicopter, falls long enough without a parachute(so the drag force has strenght kv2 ) to reach his first terminal velocity ( denoted v1). When his parachute opens, the air resistance force has a strenght Kv.
At what minimum altitude must his parachute open so that he slows to within 1% of his new
(much lower) terminal velocity (v2) by the time he hits the ground?
Newtons second law F = ma
I used Newton second law of motion and think i have to use the time t = 0 and not sure what to do again could someone help me
Please show us what you did and we can go from there.
F=ma
kv=md2x/dt2
kdx/dt=md2x/dt2
from here i don't know where to go i don't even know if this is correct does anyone know how to work it out ?
F=ma
kv=md2x/dt2
kdx/dt=md2x/dt2
This is what i did
kdx/dt=md2x/dt2
what about gravity? :redface:
i don't know i think the gravity will be the acceleration:confused:
gravity (times mass) is one of the forces on the skydiver
kv is the other force
now use Ftotal = ma :smile:
ok will try something:approve:
without a parachute(so the drag force has strenght kv2 ) ... When his parachute opens, the air resistance force has a strenght Kv.
Just checking: it's kv2 without parachute but Kv with? Not Kv2?
yes when the parachute opens it is Kv and before it is Kv2 i am mostly sure we have o use the Kv since the question asked when the parachute was open
That's not quite what it says in the OP. There you wrote kv2, not Kv2. I can cope with the change from v2 to v as the parachute opens, but it seems very unlikely the coefficient would be the same. For a start, its dimensions would be different.
However, since you're given the first terminal velocity as v1, it's irrelevant what the drag was before the parachute opened. So ignore my questions and concentrate on getting the equation when drag = Kv.
this is what i did so far
ma = mg - kv (since kv is the opposite direction as the gravitational force)
md2x/dt2 = mg - k dx/dt
this was given
Mass of Felix = 70 kg
Gravity = 9.8ms^-2
Air resistance proportional constant K = 110 kgs^-1
terminal velocity without parachute, v1 = 52ms^-1
Terminal velocity with parachute v2 = 6.2ms^-1
what do i do from here ??
ok, now rewrite that as mdv/dt = mg - kv, and integrate …
what do you get? :smile:
