How can I solve this differential equation with given initial conditions?
The discussion revolves around solving the differential equation \(\frac{dx}{dt}=-\alpha xy\) with the initial condition \(x(0)=x_0\) and \(y=y_0e^{-\beta t}\). The user initially separates variables and integrates but arrives at an incorrect final expression for \(x\). The key mistake identified is the failure to evaluate the time integral at both limits, which is crucial for determining the constant of integration. After clarification, the user realizes the premature inclusion of the \(x_0\) term and corrects their approach. The final solution aligns with the book's answer after properly applying the initial condition.
amcavoy
I have the following to solve:
\frac{dx}{dt}=-\alpha xy;\quad y=y_0e^{-\beta t};\quad x(0)=x_0
I separate variables and come up with:
\frac{dx}{x}=-\alpha y_0e^{-\beta t}dt
\ln{x}=-\alpha y_0\int e^{-\beta t}dt=\frac{\alpha y_0}{\beta}e^{-\beta t}+C
...so for a final answer I come up with:
x=x_0\exp{\left(\frac{\alpha y_0}{\beta}e^{-\beta t}\right)}
..however the book says that the answer is:
x=x_0\exp{\left(\frac{-\alpha y_0\left(1-e^{-\beta t}\right)}{\beta}\right)}
I cannot find where I went wrong, any ideas?
Thanks a lot.
You didn't evaluate the time integral at both limits.
Good catch. I stared at it for a few minutes and couldn't figure it out.
...both limits?
You have:
x(t)=K\text{Exp}\left[\frac{\alpha y_0}{\beta}e^{-\beta t}\right]
with:
x(0)=x_0
Now, carefully substitute that initial value into the equation to solve for K.
saltydog said:
You have:
with:
x(0)=x_0
Ahh, I must have put the x0 term there prematurely. Thanks for the help everyone, I have it now. :smile:
