How to Correctly Differentiate the Acceleration Equation in N-Body Simulations?
cc94
I was reading about the Hermite integration scheme for N-body simulations, as seen here: http://www.artcompsci.org/kali/vol/two_body_problem_2/ch11.html#rdocsect76
This scheme uses jerk, the time rate of change of acceleration. The problem is that I don't know how to correctly evaluate the derivative of the acceleration equation shown there.
\vec{a} = \frac{GM}{r^2}\vec{\hat{r}}
\vec{j} = GM\left(\frac{\vec{v}}{r^3} - 3 \frac{(\vec{r} \cdot \vec{v})\vec{r}}{r^5}\right)
First I rewrote the unit vector in a to get:
\vec{a}= \frac{GM\vec{r} }{r^3}
To differentiate, I applied the quotient rule:
\frac{d\vec{a}}{dt} = GM\frac{r^3\frac{d\vec{r}}{dt} - \vec{r}\frac{dr^3}{dt}}{r^6}
The first term is obviously v/r^3, but the second term is where I'm confused. I can get the right answer by using the chain rule:
\frac{\frac{dr^3}{dt}}{r^6} = \frac{3r^2\frac{d\vec{r}}{dt}}{r^6} = \frac{3\vec{r}\frac{d\vec{r}}{dt}}{r^5} = \frac{3(\vec{r}\cdot\vec{v})}{r^5}
but I'm just arbitrarily changing the scalar r into the vector r. What's the right way to do this step?
The answer is correct, but the steps are all wrong: the first because it equates a scalar to a vector, the second because it contains a meaningless multiplication of two vectors, and the third because it then somehow gets back to a scalar quantity.
Instead, keep the amounts as scalars all the way along. Start with:
$$\frac{d(r^3)}{dt}=3r^2\frac{dr}{dt}$$
Then draw a diagram and try to express ##\frac{dr}{dt}## in terms of ##\vec v## and ##\vec r##. You may find it convenient to use ##\hat r##, the unit vector in the direction of ##\vec r##, along the way.
Ok so, if we draw \vec{r} = r\hat{r} on the plane, for instance, then the change in length will depend on which direction v is pointing. In the limit of a small time step dt, the change of length r is equal to v*dt*cos(θ), where θ is the angle between v and r. I.e.
\frac{dr}{dt} = vcos\theta
So we pull one of the 'r's from in front to get r*v*cos(θ), which is indeed equal to the dot product r·v. The remaining r cancels one in the bottom to get the r^5 term.
Yes, that's it!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
