Difficulty With Integration by Parts
Shoney45
What I am unsure of is how to find the derivative of u. Since the original integral is integrating with respect to y, should I be finding the derivative of u with respect to y, and treat the x's as contants?
I think it's possible to solve it in terms of x
let u=x and dv=e^(-x(1+y))
then,
du=1
and v= [e^(-x(1+y))]/(-(1+y))
I think it should work
if you want let
u=e^(-x(1+y))
du= -(1+y)*e^(-x(1+y))
you treat y as a constant and x as a variable
(I am assuming you want to integrate in terms of x)
Alrighty then - I'll get to work. Thanks for the direction.
then,
du=1
Actually du = dx, also dv=e^(-x(1+y))dx
You can simplify this problem, by performing a w substitution at the beginning ie. consider w = -x*(1+y). It will make the integration by parts less of a headache.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
