How Do You Calculate the Angle in a Diffraction Grating Equation?
  • Thread starter Thread starter ibysaiyan
    Confused
The discussion revolves around calculating the angle in a diffraction grating equation using the given parameters: wavelength (660 nm), order (n=1), and distance between slits (d). Initially, there was confusion regarding the value of d, which was mistakenly assumed to be 3.33 meters instead of the correct unit, leading to an incorrect calculation. After clarification, it was established that d should be 3.33 micrometers (3.33 x 10^-6 m), derived from the grating specification of 300 lines/mm. The correct application of the diffraction equation n(lambda) = d sin(theta) with the proper units will yield the accurate angle. Understanding the units is crucial for solving diffraction problems effectively.
ibysaiyan
Diffracting grating?kinda confused?
bits given:lamda(660nm) n=1,d=3.33, angle=?
n(lambda)=dsin(theta)
so from re-arranging the formula,etc i got this :6.66x^-7/3.33=sin(theta)
=>2x10^-7=sin(theta)
=>angle=1.14x10^-5(after inverse sin function) ? not sure if that's the answer =/
With what you're given, the answer (in degrees) seems fine to me.
The Bob
k thanks a lot because some1 told me that i got my d wrong, =) which is not now
cant w8 to become astronomer =),need to work hard <.<,good stopped my gaming addiction.sorry if i wasnt allowed to type something out of context
As d was stated in the question, I can't see how it can be wrong. Good luck with your studies.
The Bob
ibysaiyan said:
d=3.33
What are the units for this value of d? 3.33 meters would be awfully large for a diffraction grating! :eek:
in the question was given that a diffraction grating is marked as 300lines/mm
a)find distance between slits (which i got 3.33 from 1/0.3)
lol yea distance between slits 3.33m lol can't be hmm
is probably mm
I've been away from units for too long. Yer, Redbelly98 is right. If it is 3.33mm then the answer is wrong. I apologise for assuming it was a 'plug-in-the-values' question. What's your final answer?
The Bob
the answer i got is 3.33 for d .idk where i am messing things up.
That is the key here. In 1 mm, there are 300 lines. So each line must be ____?
hmm would it be: d=1/300000=3.33x10^-6
If you include the correct units with that number, yes.
k,ty =)
