How can a digital to analogue converter be designed to produce a squared output?
  • Thread starter Thread starter simba9071
    Converter Digital
Designing a digital to analogue converter (DAC) to produce a squared output involves adjusting the output levels so that lower voltages correspond to smaller analog equivalents. One approach is to use a standard DAC in combination with an operational amplifier (Op-Amp). Alternatively, a resistor-ladder DAC can be constructed with modified resistor values to achieve the desired output. Performing the multiplication at the digital side of the converter is generally preferred for efficiency. This method allows for a more precise control of the output characteristics.
simba9071
How can you design a digital to analogue converter such that it has a squared output. i.e. the analog equivalent of the digital step is smaller at the lower voltage levels than at the higher voltage levels
I guess you could use an ordinary DAC together with an Op-Amp. Or, if it's good enough for your purposes, you could build a simple resistor-ladder DAC and change the values of the resistors accordingly.
You can do the multiply at either the digital or analogue side of the convertor, preferably the digital side.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
