What is a digital twin spark ignition system?
A digital twin spark ignition system features two spark plugs per cylinder, enhancing combustion efficiency. It utilizes a microprocessor to manage spark timing and other parameters like dwell and energy levels. The discussion references a specific application in a Bajaj Pulsar bike, highlighting the practical implementation of this technology. The digital ignition system improves performance by optimizing the ignition process. Understanding this system can provide insights into modern engine management techniques.
monty37
what exactly is this digital twin spark ignition system?
Which digital twin spark ignition system?
A twin spark system has two spark plugs per cylinder (like on my Alfa Romeo engine for instance).
A digital ignition system uses a microprocessor to control spark timing, and sometimes dwell, energy level etc.
well i was referring to a bajaj pulsar bike that uses this system,how does it work ?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
