Discover the Most Likely Room Temperature for Jack's Heat Experiment
  • Thread starter Thread starter klng
    Heat
Jack's heat experiment involved two bottles of water at 20 degC, one wrapped in a wet washcloth and the other in a dry one. After twenty minutes, the water in the wet washcloth bottle measured 18 degC, while the dry one measured 22 degC. The discussion concluded that the most likely room temperature was 26 degC, as heat transfers from a hotter to a cooler environment. The wet cloth absorbed heat from both the environment and the water, leading to a lower temperature reading. Overall, the reasoning behind the predicted room temperature was confirmed as accurate.
klng
Jack took two glass bottles containing water at 20 degC and wrapped them separately in washcloths. One of the washcloths was wet and the other was dry. Twenty minutes later, she measured the water temperature in each bottle. The water in the bottle with the wet washcloth was 18 degC, while the water in the bottle with the dry wash-cloth was 22degC. The most likely room temperature during this experiment was:
Choose one of the following options:
a) 26 degC
b) 21 degC
c) 20 degC
d) 18 degC
My predicted ans: 26 deg C. Heat has to go from a hotter environment to a cooler environment (i.e. 20 degC) to make one of the bottles (i.e. wrapped in dry cloth) attain a moderate temp of 22 deg C. For the one wraped in wet cloth, my guess is that water in the cloth is cooler than 20 deg C. Hence this wet wash cloth will absorb heat both from the environment, and the water, facilitated by water's high heat capacity.
Opinions on my reasoning?
Your reasoning is correct.
Thanks.
