Disk Scale Length Help: Troubleshooting for Science Fair
  • Thread starter Thread starter SplinterIon
    Disk Length Scale
The discussion revolves around troubleshooting the measurement of disk scale length (h) in galaxy luminosity profiles for a science fair project. The user is obtaining unusually high values for h, ranging from 7-14 kpc, while typical values are between 3-4 kpc. Key factors affecting these measurements include the quality of the images sourced from an online database and the point spread function (PSF), which describes the blurring of light in the images. Clarification is sought on whether the user is measuring surface brightness correctly, as this impacts the resulting profile shape. Understanding the PSF and ensuring accurate surface brightness measurements are crucial for obtaining reliable scale lengths.
SplinterIon
Just a quickie
I'm taking a slice of a galaxy picture and plotting luminosity vs kpc. I'm fitting a luminosity profile (de vacouleurs) and keeping disk scale length as a free parameter. However, textual values for this (referred to as h from now on) range between 3-4 kpc for most galaxies. h is defined as the radius when the luminosity decays to 1/e of its original value. My plots for most galaxies end up with h between 7-14 kpc.
Is there something I'm doing wrong? Am I missing something fundamental? Can I just chalk this down to smeared pictures and dust effects?
If this doesn't work - I'm going to photometrically integrate and hope for the best :rolleyes:
BTW: This is for a science fair (for anyone wondering)
Astronomy news on Phys.org
By luminosity, I take it you mean "surface brightness". If not, make sure that's what you're measuring. What did you use to take these images? What's the width of your PSF? If it's comparable or greater than the scale length of your galaxy, you'll measure scale lengths that are too large.
Yes, I do mean surface brightness (the reason I mentioned luminosity is that my values are in solar luminosity assuming a thin infinite disk). I didn't take the pictures myself, got it from an online database - the name evades me (I'm at school and my home comp. has the link). I scaled the pictures and preserved ratio, so I don't think it's a stretching error. They aren't the best quality in the world, but they're passable. I selected galaxies which were more or less face on - and sort of corrected for angle deviations. I don't however understand what you mean by PSF - care to elucidate?
Thanks a million.
Not to split hairs or anything, but are you sure you're measuring the surface brightness? There's no need to convert things into physical units (like luminosity) if you're just measuring a surface brightness profile. I would expect your numbers to be in units of either intensity or magnitudes per square arcsecond. If you're measuring light integrated over the disk (as denoted by a luminosity), then you would expect a different shape of profile.
When you get the info, let me know which database it is. It's not SDSS by any chance, is it?
The PSF is the point spread function and it sort of describes the "blurring" of the light by the instrument. If there's a source of light that's emanating exactly from a point, then on your image it would be blurred out into something that doesn't look like a point (more like a circular halo), and this is described by the point spread function. A galaxy is not a point source, but its light will still be blurred somewhat by the PSF. The width of the PSF should be given approximately by the angular resolution of the instrument, so if you can find that (along with the distances to the galaxies you're looking at), I should be able to tell you right away whether or not it's a problem.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
