Displacement under varying acceleration
A 7.00 kg object falls through a viscous medium and reaches half its terminal speed of 86.898 m/s in 6.14 seconds. The discussion revolves around calculating the displacement during this time, with the participant attempting to use integration to find the solution. They express confusion over their incorrect answer and seek clarification on their integration process, particularly regarding the exponential term. Feedback suggests that the integration of the exponential part may have been mishandled, leading to the erroneous result. The conversation highlights the complexities of integrating non-constant acceleration in physics problems.
MechaMZ
A 7.00 kg object starting from rest falls through a viscous medium and experiences a resistive force = -b , where is the velocity of the object. The object reaches one half its terminal speed in 6.14 s.
terminal speed = 86.898m/s
How far has the object traveled in the first 6.14 s of motion?
i don't understand why i couldn't simply use an integration of V to find the displacement since the acceleration is not constant.
the method I've tried.
v=vt(1-e(-t/T))
T=m/b
=7/b
=vt/9.81
v=86.898(1-e(-t/8.858))
\int^{t=6.14}_{t=0} vt(1-e(-t/T))dt
\int^{t=6.14}_{t=0} (86.898-86.898e-t/8.858)dt
533.55-(43.448-86.898)
577m
my answer is wrong, but i don't know why it is wrong. hope somebody could explain to me
Check your definite integration - the numbers look funny.
where it goes wrong?
\int 86.898 - 86.898 e^{-t/8.858} dt = 86.898t + (8.858) 86.898 e^{-t/8.858} + C
I can't tell exactly where you went wrong since your integration process and final integrated form is not shown, but from your values, it seems that you must have messed up the integration of the exponential part.
