How Do You Calculate the Distance Between Two Slits in a Double Slit Experiment?
  • Thread starter Thread starter JSapit
In the discussion about calculating the distance between two slits in a double slit experiment, the problem involves light of 650 nm and angles for maximum and minimum interference. The user initially struggled with the equations for constructive and destructive interference but eventually derived a formula for m by manipulating the equations. After some calculations, they realized their error in determining m, which they corrected with assistance from another user. The final value for m was found to be approximately 6.92. The conversation highlights the importance of careful mathematical manipulation in solving physics problems.
JSapit
Light of 650 nm is incident on two slits. A maximum is seen at an angle of 10.93degrees and a minimum of 11.73degrees. What is the order m of the maximum?
What is the distance d between the slits?
dsin(theta)=m(lambda) - max
dsin(theta)=(m+1/2)(lambda - min
So I started out with the two equations, one for the constructive interference and destructive interference. I solved one equation for d, and then substituted that solved equation into the other to try and find m. I don't know if it was an error in math or what, but I can't seem to solve this problem. Is there an easier way that this, or is this the easiest?
P.S. Sorry I've posted three threads for three different questions, but I'm having trouble with this chapter. Thank you for your patience and your help.
It sounds good to me. I wrote the two equations
mL = d*sin(A) and (m+.5)L = d*sin(B) and divided them to eliminate the d.
This almost resulted in a whole number - one % off. Close enough, I guess.
What did you get for your m? I took an m out after I divided the two equations, so it looked like m=(.5sinA)/sinB, which got me about .466330. I tried entering it and it wasn't right. My math is definitely wrong ._.
Dividing the 2 equations, I got
1 + .5/m = sin(B)/sin(A) = 1.072203
so .5/m = .072203
m = 6.92
That explains what I did wrong. I figured it out. Thanks for all your help Delphi!
Woohoo
