Distribution of Charge on a Conducting shell
A +30mC point charge at the center of a thick metal shell with a net charge of -50mC results in a charge distribution where -30mC accumulates on the inner surface of the shell due to electrostatic induction. This leaves -20mC to be distributed on the outer surface of the shell. The negative charge on the shell does not imply a positive charge is present; rather, the shell remains negatively charged overall. The inner surface attracts negative charge, while the outer surface holds the remaining negative charge. Understanding this distribution clarifies the behavior of charges in conductive materials.
fornax
A +30mC point charge sits at the center of a spherical thick metal shell, of 4.0cm inner radius, and 2.0cm thickness. The net charge on the shell is -50mC.
I came up with several conclusions and I'm not really sure which one is right. I'm just looking for a confirmation of how this charge would distribute itself. I learned that in such a case as this, an equal and opposite amount of charge would distribute itself across the inner surface of the shell, so -30mC. Since the net charge is then -50mC, that means that -20mC must be on the outer surface. That didn't really make much sense to though me since there is no where for a positive charge on the shell. So does that mean there's a charge of -80mC on the inner surface of the shell, and +30mC on the outside? or is it just one big negatively charged conductor?
The shell is negatively charged and the point charge at the centre attracts equal amount of negative charge onto the inner surface of the shell. The remaining negative charge distributes on the outer surface.
ehild
Thank you so much, I've been stuck on the rest of the problem. Thank you for clarifying that for me.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
