Do I have to break these problems up into component vectors?
Breaking down problems into component vectors is essential for accurately solving vector-related questions, as it simplifies the calculations involved. For scenarios #8 to #11, decomposing movements into their respective components can clarify the resultant vectors and facilitate problem-solving. In problem #12, the net force on the balloon can be determined by vectorially adding the forces from the two individuals pulling at 45 degrees, which form a right angle. The discussion emphasizes the importance of understanding the underlying questions to effectively apply vector decomposition. Overall, breaking problems into components is a recommended approach for clearer analysis and solutions.
jefgreen
#8: A person walks 60.0 m east, then 80.0 m NW.
#9: A person walks 15 m west, then walks 7.0 m @ 15 degrees South of West.
#10: Two forces act on an object. A 45 N force pushing to the north, and a 70 N force pushing at 20 degrees to the east of north.
#11: Some people go for a walk. They walk 5.4 km at 30 degrees north of east, turn and then walk 6.50x10^3 m to the west.
#12: Some people are in a hot air balloon floating above the ground. The net upward force of the balloon after the force due to gravity is 150 N. Someone is on the ground, pulling the balloon with a 50 N force at a 45 degree angle to the balloon. Someone else is on the other side of the balloon, also pulling at an angle of 45 degrees with a force of 50 N. What will be the result of this resultant force on the balloon?
8-11 I am unsure if I need to break them up into component vectors. I AM NOT ASKING USERS TO SOLVE THE PROBLEM, BUT MERELY GIVE SOME DIRECTION AS TO HOW TO SOLVE THE PROBLEMS. Also, I am clueless about 12...
bump10char.
For #8-11, will breaking them up into components allow you to solve the problems? If so, do it.
I'll try.
For #12, the tensions in the two ropes form a 90 degree angle, so simply add them vectorally and this will give you the net downward force due to the two people pulling.
As for #8-11... we don't know what the questions are asking...
jefgreen said:
bump
No success with the vector components? Show us your work and we can try to help you out.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
