Doppler Effect: Train A and B Whistle Frequency Calculation
The discussion focuses on calculating the beat frequency detected by a listener between two trains with whistles at 392 Hz. Train A is stationary, while Train B moves at 35 m/s away from Train A, and the listener moves toward Train B at 15 m/s. Using the Doppler effect formula, the frequency perceived from Train B is calculated as approximately 371.3 Hz, and from Train A, it is about 374.91 Hz. The resulting beat frequency is determined to be 4 Hz. The calculations and approach to the problem are confirmed as correct.
lc99
Two trains A and B have a whistle that blows at a frequency fT = 392 Hz. Train A is stationary and train B is moving toward the right (away from A) at a speed of vB = 35 m/s. A listener is between the two trains and is moving toward the right with a speed of vL = 15 m/s. No wind is blowing and assume the speed of sound v = 344 m/s. What is the beat frequency fbeat detected by the listener?
fL = fS [ ( V + Vl ) / (V + Vs) ]
V = 344 m/s
for frequency of L by train B -
fL = 392 [ (344 - 15)/(344 +35) ] = 371.3
for train B
fL = 392 [ (344-15) / 344 ] = 374.91
375-371 = 4 = fbeat
V = 344 m/s
for train B
375-371 = 4 = fbeat
Looks right to me.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
