Double Integral - Evaluate ∫∫D xy dA
  • Thread starter Thread starter shards5
    Integrals
shards5
Evaluate the double integral ∫∫D xy dA where D is the triangular region with vertices (0,0) (6,0) (0,1).
0 <= x <= -\frac{1}{6}x+1
0 <= x <= 6
the first integral would be the integral from 0 to -1/6x+1 of xy with respect to y
which gives me \frac{x*y<sup>2</sup>}{2} which I plug in -1/6x + 1 into to get
\frac{1/36x^3-12x^2+1/36x}{2}
Integrating that I got x^4/288 - x^3/72 + x^2/4, which is wrong. I am not sure what I did wrong.
Fixed up your LaTeX. Tip: Don't use [ sup] and [ /sup] inside [ tex] tags.
0 <= x <= 6
which gives me \frac{x*y^2}{2} which I plug in -1/6x + 1 into to get
You should get (1/2)[(1/36)x3 - (1/3)x2 + x]
Whoops, I forgot to add in a step. However, when I integrate that I get what I have shown in my question and when I evaluate it on the interval from 0 to 6 I am getting the wrong answer which makes me think that maybe I am doing something else wrong.
There are lots of opportunities for arithmetic mistakes. This is what I got.
(1/2)\int_0^6 (x^3/36 - x^2/3 + x)dx = (1/2)\left.(x^4/144 -x^3/9 + x^2/2)\right|_0^6
After evaluating at 6 and 0, I ended up with 3/2.
Oh, I see what I did wrong, I thought that 1/6+1/6 was 1/12. Thanks a lot for checking my work.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
