Dr/Dt world coordinates problem
  • Thread starter Thread starter yetar
    Coordinates
The discussion centers on the relationship between the rate of change of position in rigid body dynamics, specifically the distinction between Dr/Dt and dr/dt. Dr/Dt represents the rate of change of position in world coordinates relative to body coordinates, expressed as Dr/Dt = dr/dt - wxr. The user seeks clarification on the terminology for Dr/Dt and how to prove that the operators D/Dt and d/dt follow the same rules. They encountered contradictions while attempting to apply the operators to vector products, leading to confusion about their equivalence. The conversation emphasizes the need for a deeper understanding of these operators in the context of rigid body motion.
yetar
In rigid body, r is the position of a rigid body relative to world coordinates,
dr/dt is the rate of change of r in world coordinates.
I encountered the term Dr/Dt as the rate of change of r in world coordinates relative to the body coordinates system.
And that Dr/Dt = dr/dt-wxr
My question is, how does Dr/Dt is called? (terminology)
Also the operator D/Dt has the same rules as the operator d/dt, how do you proove it? There is some relationship to proove this, but what is this relation ship?
Dr/Dt = dr/dt-wxr
I tried to use Dr/Dt = dr/dt-wxr to proove that both operators has the same rules, but didnt succed.
In matter of fact, I found some contradiction.
For instance: d(AxB)/dt = Ax(dB/dt)+(dA/dt)xB
So D(AxB)/Dt = Ax(DB/Dt)+(DA/Dt)xB should also be true.
However using Dr/Dt = dr/dt-wxr showed that there is inequality.
Thank you.
I prefer the notation
dr^s/dt=dr^b/dt-wxr
where r^s = space fixed r (with subscript s) and r^b = body fixed r
The d/dt operator is the same in both cases.
There's a good, but lengthy article here
http://python.rice.edu/~chem630/Polyatomics.pdf
