Dynamical Equations & Free Body Diagrams: Solving for Net Force and Torque
  • Thread starter Thread starter ~christina~
The discussion revolves around solving a physics problem involving a car and a mass connected by a string over a pulley. Participants seek clarification on drawing free body diagrams for the car, mass, and pulley, particularly regarding the forces acting on the pulley. There is confusion about the term "dynamical equations of motion," with participants emphasizing the need to understand how to calculate net forces and torques. The relationship between tension, acceleration, and the motion of both masses is highlighted, noting that they will accelerate uniformly but in opposite directions. Overall, the thread emphasizes the importance of correctly applying concepts of dynamics and free body diagrams to solve the problem.
~christina~
A car of mass m_c is connected to mass m2 by a string. The string passes over a solid cylindrical pulley, which has a frictionless bearing, of radius R and mass M. when the system is released from rest the string doesn't slip, the car moves down the incline, and m2 moves upward through a distance h' .
a) draw a free body diagram for m_c, m_2, and M
b) Use the dynamical equations of motion to find the components of the net force aceting on m_c and m_2 and net torque acting on M.
c) Use the results of b) to derive a expression for the translational aceleration for the masses in terms of m_c, m_2, M, h', 2 and the coefficient of friction \mu
http://img263.imageshack.us/img263/7160/carhj5.th.jpg
dynamical equations ==> what is that exactly??
a) a) draw a free body diagram for m_c, m_2, and M
I drew it in with a picture of the drawing but I'm not sure the free body diagram of the pulley since I've never drawn a free body diagram of a pulley before. What forces would be on it other than that of the car and block?
b) b) Use the dynamical equations of motion to find the components of the net force aceting on m_c and m_2 and net torque acting on M.I have no clue how to do this part at all.
What are the dynamical equations of motion?
HELP Please
Dynamic equation is the equation of the body under motion. In this problem it is possible that Mc and M2 can remain at rest. You can describe this condition by some static equation. In this problem the tension in the string and acceleration of the car and the mass is same. Using free body diagram calculate acceleration. From that you can find the torque acting on the pully.
hey
for a) it should be McA (in your free-body diagram on M, the Mc needs an acceleration)
for c) is H' the distance, or the rate at which the height is changing. and what is "2"?
you should also note that, since the tension is uniform and the mass of the string is negligible, both of the masses will be accelerating with the same magnitude, but different direction, right?
aq1q said:
hey
I'm not sure what is "2" but thanks for catching the Mc A
I have no idea what you are talking about...is it involving sum of F in one direction of one object?
Yes...
but I'm thinking the whole wording of "dynamic equation" is messing with me since I know how to do tension and etc. but I've not heard of "dynamic equation" and I'm not sure what they want...or how to relate that to torque...
