Bystander said:
Here now, don't go destroying my faith in you. Conflation of ideas from too many threads and the distraction in Current Events right at the moment. What had crossed my mind was a radial differentiation of atomic masses by solar wind when/while the planetary nebula(e) were still diffuse enough to suffer such effects leading to a relative enrichment of heavier elements in the more sunward accretion discs; anything like that crossed your path?
I'm not sure about the solar wind itself but I do know solar radiation played a role in radial differentiation of atomic masses (and not just through heating and vaporisation of volatile elements either).
The chondrites (primitive, undifferentiated meteorites) are classified into groups based on their volatile content, iron content and oxidation state and oxygen isotope ratios. The volatile content tells us roughly how far out in the solar nebula they formed (since obviously the proto-sun would have vaporised volatiles closer into it), and iron oxidation state fits in well with this (the equilibrium condensation model tells us that solids that condensed at high temperatures will have a lower oxidation state for iron/more reduced iron, since iron metal condenses at a higher temperature than olivines and pyroxenes (containing iron (II)), which condense at a higher temperature than magnetite (containing iron(III), and we find that in general the more oxidised the iron of a meteorite is, the more volatile elements it contains - two independent lines of evidence that some meteorites formed further out in the solar nebula than others.)
These chondrites also vary in oxygen isotope ratios - those that appeared to have formed further out have relatively more
16O (compared to the much rarer and heavier stable isotopes,
17O and
18O) than those further in. One possible explanation is the fact that a significant amount of the oxygen in the solar nebula was tied up in carbon monoxide, which is ubiquitous throughout the universe, and which had to be split to release the oxygen and "free" it to react and form the silicate phases we see in meteorites. Different wavelengths of solar UV radiation photodissociate CO molecules (i.e. split them up) containing different oxygen isotopes.
Since
16O is an incredibly abundant isotope (99.8% of the CO in the protoplanetary disc was
12C
16O), the
16O dissociating wavelength did not penetrate any significant distance into the disk (as there was so much C
16O to absorb it). This means that out where the inner planets formed, there were more of the
17O and
18O dissociating wavelengths, splitting more CO molecules containing these isotopes and "freeing the oxygen atoms" up to react and form more silicate minerals with an enrichment of these isotopes. Even farther out in the disk, however, even these wavelengths would have been absorbed, making meteorites that formed in the outer parts of the asteroid belt relatively poor in
17O and
18O relative to
16O compared to those meteorites that formed further in. This hypothesis is known as
spectroscopic self-shielding, and implies that the solar system on average is richer in
16O than Earth and the other terrestrial planets (which got an enrichment in
17O and
18O due to their distance from the Sun - far out enough to not absorb much C
16O-dissociating radiation, but to absorb a lot of C
17O and C
18O dissociating radiation.).
This was found to be true by the Genesis mission, which captured some of the solar wind and analysed it isotopically (assuming of course that the Sun's composition represents the average solar system composition, which is a fair assumption to make given that the Sun represents 99.86% of the solar system's mass!). The Sun is indeed enriched in
16O relative to the inner planets.
I know this has nothing to do with the solar wind but I bring it up as an example of how solar radiation can affect the radial composition of the solar nebula beyond simple heating!
Edit: Everyone talking about the late heavy bombardment as the source of iron in the crust since iron would have been dragged down into the core during differentiation - please remember the core contains
metallic iron! Oxidised phases of iron in silicates are less dense and there'd be no problem with them remaining in the crust (or mantle and then being brought up to the crust during volcanism) from the Earth's formation. Take the ferromagnesian minerals that make up much of the oceanic crust, for example.
