Easy integration by parts question.
Kuma
Hi
This is something i don't remember what I'm supposed to do. So anyway here goes.
For example if my function was
xe^yx and i wanted to integrate with respect to dx
then i do an integration by parts with these variables:
u = x dv = e^yx
now my question is, when i try to find du do i differentiate with respect to x? same goes for dv, do i integrate with respect to dx?
suppose instead i chose
u = e^yx and dv = x
then du would be ye^yx?
Hopefully that was clear enough.
Kuma said:
u = x
dv = e^yx
Yes.
Technically, your "dv" expression should be:
dv = eyxdx
...so there's not much to be confused about on that part, at least.
ok thanks
remember you need
u du v dv
you know u=x dv=e
du=dx v=(1/y)eyx
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
