Easy integration by parts question.
Kuma
Hi
This is something i don't remember what I'm supposed to do. So anyway here goes.
For example if my function was
xe^yx and i wanted to integrate with respect to dx
then i do an integration by parts with these variables:
u = x dv = e^yx
now my question is, when i try to find du do i differentiate with respect to x? same goes for dv, do i integrate with respect to dx?
suppose instead i chose
u = e^yx and dv = x
then du would be ye^yx?
Hopefully that was clear enough.
Kuma said:
u = x
dv = e^yx
Yes.
Technically, your "dv" expression should be:
dv = eyxdx
...so there's not much to be confused about on that part, at least.
ok thanks
remember you need
u du v dv
you know u=x dv=e
du=dx v=(1/y)eyx
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
