Easy Vertical Motion Question
In summary, the question asked for the height of a window above the ground, given that an object was thrown vertically at 18m/s and took 1.6 seconds to hit the ground. The answer would depend on whether the object was thrown upwards or downwards, with the possibilities being 41.3 meters, if thrown downwards, and 16.3 meters, if the window was below ground. The question was ultimately removed from the test.
Inquiring_Mike
50
"Easy" Vertical Motion Question
Hey,
This question was on my test today, but it didnt seem right to me..
Q) An object is thrown vertically at 18m/s from a window and hits the ground 1.6s later. What is the height of the window above the ground?
Is this even possible?
Vertically up or down?
Use s = ut + 0.5 a*t^2
You got the t, you got the u, you got the a.
Seems pretty possible... :wink:
Vertically up.
But how can the entire trip only take 1.6s if the object is shot upwards at 18m/s? Wouldn't it take at least that long to slow the ball down so it could work on its down trip?
Were you specifically told "up"? If an object is thrown upwards at 18 m/s, then it will take 18/g= 18/9.8= 1.8 seconds for the object to reach its highest point. Obviously it can't hit the ground before that.
On the other hand, if the object is thrown vertically downwards at 18 m/s, the distance traveled at time t is x= 18t+ (g/2)t2.
With t= 1.6 seconds, g= 9.8 m/s2, that gives
x= 18(1.6)+ 4.9(1.6)2= 41.3 meters.
Another possibility is that the window is below ground!
Throwing an object up at 18 m/s gives a height of x= 18t- (g/2)t2. With t= 1.6 and g= 9.8, that gives x= 18(1.6)- (4.9)(1.6)2= 16.3 meters. The ground is 16.3 meters above the window!
Thanks for the help everyone!
It was up and I told my teacher and he took the question off the test...
What is "easy vertical motion"?
"Easy vertical motion" refers to the motion of an object moving in a straight line up or down, without any external forces acting on it.
What are some examples of easy vertical motion?
Some examples of easy vertical motion include throwing a ball straight up in the air and a person jumping off a diving board and landing back in the water.
What is the difference between easy vertical motion and free fall?
The main difference between easy vertical motion and free fall is that in free fall, the object is accelerating due to the force of gravity, while in easy vertical motion, the object is moving at a constant speed.
What are the equations used to calculate easy vertical motion?
The equations used to calculate easy vertical motion are displacement (d) = initial velocity (vi) x time (t), final velocity (vf) = initial velocity (vi) + acceleration (a) x time (t), and displacement (d) = 1/2 x acceleration (a) x time squared (t^2).
How does air resistance affect easy vertical motion?
Air resistance can affect easy vertical motion by slowing down the object's speed due to the force it exerts in the opposite direction of the object's motion. This can cause the object to take longer to reach its maximum height or to fall back to the ground.
