- 8,700
- 4,779
Both in classical mechanics and in quantum mechanics, the system has a state, which is its only reality. Measurements reveal part of this reality to a certain accuracy. It is a matter of modeling how the measurement results are related to the true reality - the state. In the statistical mechanics of ##N##-particle systems, what is measured (both in classical and in quantum mechanics) is the expectation of a macroscopic operator, to an accuracy of order ##O(N^{-1/2})##. This is enough to give well-defined pointer readings. Thus no collapse is needed to make the pointer acquire a well-defined position. As a consequence of having definite macroscopic outcomes (plus the Markov approximation) one finds that the dynamics of the subsystem is described by a PDP.atyy said:Don't focus on collapse. Focus on the measurement outcome, which needs no collapse. If one has a unitarily evolving wave function, at what point in time does the particle acquire a position?
It is different from classical physics where the particle has a position, before any coarse graining that makes friction appear.
But although the pointer reading is a position measurement of the pointer, what is measured about the particle is not its position but the variable correlated with the pointer reading - which is the photon number or the quadrature. Particle position is as indeterminate as before. Indeed, investigation of the PDP process shows that the collapsed states created by the PDP are approximate eigenstates of the number operator or the quadrature. Thus the PDP can be interpreted in Copenhagen terms as constituting the repeated measurement of particle number or quadrature.
