Egative power indicates an inverse
  • Thread starter Thread starter gillgill
    Inverse Power
The discussion explains the behavior of exponential functions for positive and negative values of x, specifically comparing 3^x, e^x, and 2^x. For x > 0, the inequality 3^x > e^x > 2^x holds true, while for x < 0, the reverse inequality 3^x < e^x < 2^x applies. This shift occurs because negative powers represent inverses, making smaller bases yield larger values when raised to negative exponents. The relationship is further clarified using logarithmic properties, indicating that if a < b, then 1/b < 1/a when both a and b are positive. Understanding these properties helps clarify the behavior of exponential functions across different ranges of x.
gillgill
Why is 3^x > e^x > 2^x when x>0, but 3^x < e^x < 2^x when x<0?
e is approx. 2.72
so 3^1=3
2.72^1=2.72
2^1=2
therefore 3^x>e^x>2^x when x>0
however, when you get into the negatives
3^-1=1/3
2.72^-1=1/2.72
2^-1=1/2
this is because a negative power indicates an inverse( 1/x ), so the smaller the number with a negative power, the smaller the denomenator will be
Another way of looking at it. Since 3 > e and therefore Log(3) > 1, x Log(3) > x implies x > 0 and x Log(3) < x implies x < 0.
All this is saying is that if 0<a< b< c then 0< 1/c< 1/b< 1/a
If a< b and a and b are positive, then 1< b/a because we have divided by a positive number.
Then 1/b< 1/a because we have divided by a positive number.
