Electric Blanket for a flow rig
  • Thread starter Thread starter zymil
    Electric Flow
To maintain a constant temperature of 30C for a flow rig made of acrylic, using electric heat trace cable is suggested, along with a simple controller to regulate the temperature. Insulation is crucial for effective temperature maintenance, and options include fiberglass, mineral wool, or calcium silicate for added structural strength. The placement of the temperature sensor should be at a point that reflects the average temperature of the rig. Proper insulation will enhance the performance of the heat trace cable. Achieving the desired temperature requires careful consideration of energy input and insulation materials.
zymil
Hi all,
I'm designing a flow rig for my project. I'm running out of ideas on how to keep the rig at constant temperature of about 30C. The rig is made of acrylic, 10mm diameter, and the total length is about 1m.
Any kind of input is appreciated.
Regards,
Jeff
Welcome to PF.
You will need to figure out how much energy input is required to keep it at 30 C.
Given the length of 1m, your simpliest solution is likely electric heat trace cable. You can get a simple controller to maintain your 30C setpoint. Then insulate around the heat trace cable and put your temperature instrument that feeds the controller at a location you consider to be the average temperature.
Hi edge, thank you for your reply. I've been trying to use heat trace cable but it is hard to maintain the temperature at 30C without any insulation.
What sort of insulation do you think i use?
I would recommend fiberglas or mineral wool. If you need something with some structural strength you can use calcium silicate.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
