Electric current and forces problem
The discussion revolves around calculating the force on one wire in a setup of three parallel wires arranged in an equilateral triangle, each carrying a current of 50A. The user is confused about the distance to use in the force calculation and how the wires can be both parallel and in a triangular formation. It is clarified that the distance between the wires is 10 cm, which is the side length of the triangle. The user acknowledges the guidance received and agrees to post future homework questions in the appropriate forums. Overall, the conversation highlights the importance of understanding wire arrangements and force calculations in physics.
steve12
Hi,im trying to work out this problem but i am slightly confused by the way in which it is phrased.It states:
Three parallel wires,arranged in the form of an equilateral triangle, of side length 10cm,each carry a current of 50A in the same direction.Calculate the force on anyone wire due to the other two.
I am going to use: F = (2*10^-7)(50)(50)/d
however i don't know what value to enter for the distance d between them.i also don't understand how the three wires can be parallel yet arranged in the form of an equilateral triangle??do i just resolve the components of one wire into parallel and perpendicular to the 2nd wire and use the parallel value in my calculations maybe?
any help or guidance would be much appreciated
thanks steve:smile:
The wires (#) are arranged like so;
(ignore the dots) going into and out of the screen; therefore d = 10cm in each case. Please post your homework questions in the homework forums in future, thanks :smile:
oh i see,thanks a mill for that!and sorry-will do in future!
cheers
steve
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
