Electric Field and Forces Problem?
A point charge of mass 0.210 kg and charge +0.340*10^-6 C hangs at rest, influenced by a uniform vertical electric field from a nearby charged sheet. The tension in the string is 5.67 N, leading to the calculation of the electric field strength using the equation E=F/q. The net force acting on the charge is determined to be 3.612 N, resulting in an electric field magnitude of approximately 10,623,529.4 N/C. There is uncertainty regarding the direction of the electric force, with a suggestion that it must be downward to balance the forces in the system. The discussion emphasizes the importance of understanding both the magnitude and direction of electric fields in this context.
AnnieF
A point charge of mass 0.210 kg, and net charge +0.340*10^-6C, hangs at rest at the end of an insulating string above a large sheet of charge. The horizontal sheet of uniform charge creates a uniform vertical electric field in the vicinity of the point charge. The tension in the string is measured to be 5.67 N. Calculate the magnitude and direction of the electric field due to the sheet of charge.
E=F/q
F=Q1Q2K/r^2
I am not entirely sure how to do this, but this is my guess..could someone tell me if I am doing this right?
Ft-mg-Fe=0
Fe=Ft-mg
Fc=3.612 N
E=F/q
E=3.612/.340E-6
E=10623529.4 N/C
I am not sure how to tell what direction it will be in
Ft-mg-Fe=0
Fe=Ft-mg
Fc=3.612 N
E=F/q
E=3.612/.340E-6
E=10623529.4 N/C
Looks good.
Can you tell what the direction of the electric force is?
Well I was thinking that it would have to be down, because the force of tension is greater than the force of gravity, so in order for the system to be not moving, the other force would have to pull downwards in order to cancel out the larger force of tension. Is this right?
