Electric Field & Capacitor Problem HELP
An electron enters a parallel plate capacitor with an initial speed of 4.00 x 10^6 m/s and exits after curving upward. The capacitor dimensions are 2.00 cm long and 0.150 cm apart, with a uniform electric field. To find the electric field's magnitude, the force on the electron can be calculated using F=ma=qE, where q is the charge of the electron (1.6 x 10^-19 coulombs). The time taken for the electron to travel horizontally can be determined using t=d/v, allowing for the calculation of acceleration and subsequently the electric field. The discussion emphasizes the importance of using kinematics and the known properties of the electron to solve the problem.
isufuaks
Electric Field & Capacitor Problem...HELP!
An electron enters the lower left side of a parallel plate capacitor & exits at the upper right side making an upward curve. The initial speed of the electron is 4.00 x 10^6 m/s. The capacitor is 2.00 cm long, and its plates are separated by 0.150 cm. Assume that the electric field between the plates is uniform everywhere and find its magnitude.
So I understand that F=ma=qE. I also understand that I can use kinematics to find the acceleration and I can also use the mass of an electron to figure out the force. However, how do I find q? I'm so confused!:confused: Please help! Thanks!
q is the charge on an electron. Look it up in your text.
q=e=1.6x10^{-19} coulombs...
in the vertical direction, the electron has traveled 0.15 cm (from lower left corner to upper right corner). the initial speed in the vertical direction is 0
=> distance = a*t^2/2 (a= acceleration and t- time)
the time is found by: t= d/v (in horizontal direction) = 2 cm/ speed
so now you can find a, and then E.
Good luck.
