Electric field - find earths electric charge
The discussion focuses on calculating Earth's electric charge based on a measured electric field of 150 N/C directed towards the center of the Earth. The user attempts to solve the problem using relevant equations but arrives at an incorrect charge value of 2.64 X 10^32 C, while the expected answer is 6.77 X 10^5 C. Key equations include the relationship between electric field strength, force, and charge, specifically |E| = k|qs| / r^2. The user is advised to use Earth's radius for r and correctly solve for q, considering the sign of the charge. The conversation emphasizes the importance of applying the correct values and equations to achieve the right result.
XxphysicsxX
Measurments indicate that there is a weak electric field of 150 N/C surrounding the Earth that points towards the center of the earth. Determine the absolute value of the electric charge of earth.
F|e| = ma
|E| = |Fe| / |qt|
|E| = k|qs| / r^2
Mass of Earth = (5.9 X 10^24 kg)
radius of Earth = (6.37 X 10^6m)
|E| = (5.9 X 10^24 kg)(9.81 m/s)
|E|= 5.85 X 10^ 28
5.85 X 10^ 28= ((8.99X 10^9)(qs)) / ((6.37 X 10^6m)^2
qs= 2.64 X 10^32
which is not even close to the right answer... its supposed to be 6.77 X 10^5 C
Thankyou in advance!
|E| = k|q| / r2
You are give |E| and the direction of E.
Use Earth's radius for r.
Solve for q.
Figure out the sign of q.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
